Hi everyone,
I am trying to get an ESP32-S3 based touch LCD working with ESPHome.
Hardware:
- Board: Waveshare ESP32-S3-Touch-LCD-3.5B
- ESP32-S3
- Display: 3.5" LCD (ILI9488 based)
- ESPHome version: 2026.5.3
- Home Assistant integration via ESPHome Device Builder
- Power connection: USB-C
The display works perfectly when powered from my laptop USB-C port.
However, when I power it from a USB wall charger, the display immediately becomes corrupted/garbled.
Examples of power supplies tested:
- Apple iPhone charger (original)
- Apple iPad charger
- Brand new Raspberry Pi USB-C power supply
- Same USB-C cable as used with laptop
The issue happens immediately on power-up. The ESP32 boots, but the LCD image is pixelated/garbled and unreadable.
There is no change to the firmware or cable — only the power source changes.
The same cable works:
- Laptop USB → display OK
- USB charger → display corrupted
I have checked:
- Firmware is identical
- ESPHome configuration is identical
- Cable is identical
- Multiple known-good USB-C power supplies tested
Any advice on where to troubleshoot would be appreciated.
Thanks.
