I’m currently trying to implement PV surplus charging and need to be able to start vehicle charging from within the car. For this, I need a Bluetooth connection to the car.
After searching for a solution, I came across the ESP32-S3 module. However, I can’t seem to find a suitable kit that includes both the module and a proper enclosure/case.
Maybe someone here is using this module and could recommend a suitable kit or enclosure?
perfect man thanks exactly what I was searching for. I can’t use a vertually device as my problem is the distance between my HA device and the car. My understanding is that EPS32-S3 is kind of bridge. So HA can communicate to it via WiFi and the EPS32-S3 can establish the bluetooth connection to my car. But correct me if I’m wrong or you have any better solution for this use case Thanks guys
You can use XIAO ESP32-S3. It is perfect suited for BLE projects. If you need Ethernet, the XIAO W5500 Ethernet Adapter is even more interesting. It combines ESP32-S3, Ethernet, and a ready-made enclosure. ESPHome also supports this hardware for Bluetooth proxy applications.
Check your car’s BLE protocol first. The ESP32-S3 provides Bluetooth hardware, but it doesn’t automatically provide the required car integration.
You may also want to look at this project: Universal Smart-Home Modular Hub. It uses an ESP32-S3. It is designed around Wi-Fi/BLE and Home Assistant-style IoT applications. It can be useful as a reference for designing a permanent board.
