Esp32 Voice Assistant to Echo Dot
Hi everyone, I made a voice assistant using an ESP32 board and a button microphone. I don’t have a speaker attached to it because I was hoping to send the TTS to my Echo Dot. But it’s not working; the assistant works fine, but the Echo Dot doesn’t play anything.
Here’s the code:
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO26   #WS / LRC
    i2s_bclk_pin: GPIO25    #SCK /BCLK
microphone:
  - platform: i2s_audio
    adc_type: external
    pdm: false
    channel: right
    bits_per_sample: 32bit
    i2s_audio_id: i2s_in
    i2s_din_pin: GPIO32
speaker:
    dac_type: external
    i2s_dout_pin: GPIO27   #DIN
    i2s_mode: primary
voice_assistant:
  microphone: mic_i2s
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 4.0
  use_wake_word: false
  speaker: null
  on_tts_start:
    - homeassistant.action:
        service: notify.alexa_media_pc_room
          message: "{{ my_stt }}"
        variables:
          my_stt: return x;
  on_error:
   - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - switch.turn_off: use_wake_word
          - switch.turn_on: use_wake_word
  on_client_connected:
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
binary_sensor:
  - platform: status
    name: API Connection
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
          then:
    on_release:
      - if:
          condition:
          then:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
Anyone attempted something similar and got it working?
