Esp32 who will automatically restart the router if internet is off
HI every ones,
Newbie on esphome, i am building a device with esp32 who will automatically restart my 4g router if internet is off, true on relay (yellowLED).
So far it works not so bad but i would like to get some recommendations / tips / cleanings about the code i am writing and forget a little bit about my “Arduino ide way to think”
Thanks in advance :slightly_smiling_face:
esphome:
  friendly_name: myesp
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  password: ""
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.109
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# External components
external_components:
  - source:
      type: git
      url: https://github.com/trombik/esphome-component-ping
      ref: main
globals:
  - id: connect_check
    type: int
    restore_value: no
    initial_value: '0'
  - id: connect_status
    type: bool
    restore_value: no
    initial_value: '0'
output:
  # Success connection LED
  - platform: gpio
    pin:
      number: 32
      mode: output
    inverted: false
  # Relay LED
  - platform: gpio
    pin:
      number: 33
      mode: output
interval:
  - interval: 30s
    then:
      - sensor.template.publish:
                state: !lambda '
                id(connect_check) += 1;
                return id(connect_check) ;'
                state: !lambda '
                return id(connect_status) ;'
      - if:
          condition:
             lambda: 'return (id(connect_check) > 5 && id(connect_status) == 0);'
          then:
            # relay off
            - lambda: 'id(restart_wifi).execute();'
          else:
            # relay on
            - output.turn_off: yellowLED
            - delay: 5s
      - if:
          condition:
             lambda: 'return id(connect_check) > 10;'
          then:
            - lambda: |-
               id(connect_check) = 0;
      - lambda: |-
          ESP_LOGI("main", "connect stat: %d",id(connect_status));
          ESP_LOGI("main", "check time : %d",id(connect_check));
script:
  - id: restart_wifi
    then:
      - output.turn_on: yellowLED
      - delay: 20s
      - switch.turn_on: restart_esp
switch:
  - platform: restart
    name: "Living Room Restart"
    name: "connect check Sensor"
    update_interval: never
    name: "connect status Sensor"
  - platform: ping
    ip_address: 8.8.8.8
    num_attempts: 4
    timeout: 1sec
    loss:
      on_value_range:
        - below: 90.0
          then:
            - output.turn_on: redLED
                state: !lambda '
                id(connect_status)=1;
                state: !lambda '
                id(connect_check)=0;
        - above: 90.0
          then:
            - output.turn_off: redLED
                state: !lambda '
                id(connect_status)=0;
                state: !lambda '
    update_interval: 60s
