Hey! I’m having issues connecting my ESP32Cam in any way - i’ve tried everything from pressing buttons to installing extra drivers would anybody know any kind of fix for this - i’d like to install AI ON THE EDGE but i cannot get the esp to connect.
It’s giving out Wi-Fi i can see it listed but i cannot add a code to it & it gives me the same error or write timeout
On my laptop whichever port i input the cable into it shows COM-4 port & doesn’t seem to change
Windows you likely need to load the driver for the serial chip you are trying to talk to. You MUST use edge or chrome, no other browsers will likely work.
If you are using Linux, does the user trying to flash it have permission for dialout? Also you have to use chrome.
If you try to load something and it can’t talk to the chip, the pop-up (unless you have it blocked) tells you all this.
The solution as of right now i have found is that you must press both reset & I00 buttons on the ESP to put it in download mode which will then allow you to install anything on it.
I am now facing another issue where the SD Card causes a flashing red light as i’m trying to setup AI ON THE EDGE
I initially put it in the Hardware section ye tit seems it automatically switched to ESPHome - i am planning on using esphome i am just having tons of trouble with this ESP
