ESP32Wroom32E W5500 LAN SPI and second device at same SPI?
Can´t i use the SPI Bus from ESP32Wroom32E for the W5500 Ethernet and a AS3935 Lightning Sensor at the same time? I use different CS Pins.
But when i configure SPI, it say’s Pins are in use (Clear used for the W5500 Ethernet) but if i remove the SPI Pins out of the ethernet part, Ethernet will not work.
SPI is a Bus, should be possible to use multible devices right?
