I am wondering if it is possible to program a nodemcu/wemos d1 mini pro board along with a relay board like this so that it triggers an open/close of my gate.
I think it should work ok as long as the relay can be set up as a momentary switch which I can connect to the Open connector on my gate’s board:
Gates just looking for closure of contact for open/ close/hold inputs
What your trying is great use. Only issue is ensuring WiFi signal to location. Mine was >200’ so I use ubuiquiti PtoP AP pair and add switch at remote location. Camera and RasPi used Ethernet for connection
Thanks for confirming, I suspected it should be as simple as that.
I need it to control two gates, hence the double relay and the gates also have one of those wired magnetic alarm sensors, to detect if open/closed so it should be straightforward enough to wire I believe.
Yes I currently have a gogogate2 system that controls the gates but having horrible connection issues with it.
I suspect something is wrong with the HA integration however because the gogogate2 app works ok and I even tried LAN cable and still many disconnects, HA only.
I plan to use a w1 mini pro with the external antenna for better signal - I think my issue is wifi pollution from neighbors
