I just installed and ESP32-CAM and it appeared to be a successful install.
However, the Activity section gives me the message that the Firmware has been turned off.
What does that mean?
Why is it turning off?
How can I get it to turn on?
(I am a newbee so relatively clueless)
I was able to get this to work by copying a yaml file I found on the internet.
Don’t know what the problem was but it’s working now.
Sorry about bothering people with this newbee problem. I’m learning.
Hi, good that it is solved!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
- this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
- this prevents that someone else steps in trying to help
Thanks for giving back to the community! ![]()
