Espeasy lcd display
I have esp8266 with lcd_pcf8574 as LCD display.
I am trying to ‘rotate’ the lcd with several sensor values.
What is the best way to do it? lambda ? Page does not seem to work for this display.
This is part of my yaml config:
text_sensor:
  - platform: homeassistant
    entity_id: sensor.livingroom_temperature
    name: "Livingroom temperature"
    internal: true
    entity_id: sensor.livingroom_humidity
    name: "Livingroom humidity"
    internal: true
    entity_id: sensor.outside_temperature
    name: "Outside temperature"
    internal: true
    entity_id: sensor.pressure
    internal: true
i2c:
  sda: D3
  scl: D4
display:
  - platform: lcd_pcf8574
    dimensions: 18x4
    address: 0x27
