ESPHome implements an on-device wake word detection framework from microWakeWord. See the component documentation for details on how to use it.
Check out the live stream replay below for more details about how it works and came to be.
@apbodrov has added support for the BME280 sensor over SPI. This change is a breaking change
for any existing configurations using the BME280 over I2C as the platform name has been changed from
bme280 to bme280_i2c. There are no other configuration changes required to continue using the BME280 over I2C.
See the component documentation for the latest configuration variables.
@ssieb has changed the CSE7766 sensor from appearing to be a polling component. It has a high update rate, so if you don’t want to send a lot of data to HA, you can add the throttle_average filter with the time period you were using for the update interval (the default is 60s) to each sensor. The example in the sensor doc page has been updated to show this.
For the complete list of every merged pull request in this release, see the full 2024.2.0 changelog.
This is a companion discussion topic for the original entry at https://esphome.io/blog/2024/02/21/esphome-2024-2/
