ESPHome 2024.3.0: Date entities and IPv6 - ESPHome - Smart Home Made Simple
ESPHome now has support for date entities that can be set from the frontend (like Home Assistant) for you to check against and execute automations in the future.
ESPHome Dates require Home Assistant 2024.4 or later.
ESPHome is now prepared for the future! The future that is the old IPv6 that is. Dualstack is added and it could now have up to 5 ip addresses of any type, and communication with Home assistant, MQTT and NTP works with IPv6. ESPHome still depends on IPv4, but the crystal ball shows sign of IPv6-only networks.
If you are building an External Components or you use network::get_ip_address(), wifi::global_wifi_component->get_ip_address() or ethernet::global_eth_component->get_ip_address(), these functions have been renamed to ::get_ip_addresses() respectively and now return a list of all IP addresses.
We would like to thank all Home Assistant Cloud subscribers for their support. It allows Nabu Casa to employ two developers to maintain and further develop the ESPHome project.
For the complete list of every merged pull request in this release, see the full 2024.3.0 changelog.
This is a companion discussion topic for the original entry at https://esphome.io/blog/2024/03/20/esphome-2024-3/
Talking about reviving ‘old’ stuff…
I really wonder: what’s the use of linking/duplicating/call it what you want, blogs into the forum?
Is this an error or an overactive member?
Unless I’m missing something (obvious), the main website already has the Blog section.
What is the sense in this?
