ESPHome 2024.4.0: Time entities and voice assistant audio over the API - ESPHome - Smart Home Made Simple
ESPHome now has support for time entities that can be set from the frontend (like Home Assistant). This allows you to set a timer to execute future automations on device.
ESPHome Dates require Home Assistant 2024.4 or later.
This release adds support for sending and receiving audio to/from voice assistants via the API. Currently ESPHome sends and receives the Voice Assistant audio bytes via a UDP socket which can be unreliable and insecure. Beginning with Home Assistant 2024.5, both sides will automatically recognise that they both support API Audio and will use that route instead. This is more reliable because the ESPHome API uses a TCP socket, so packet order and delivery is guaranteed, and if you use API Encryption, your audio will also be encrypted in transit.
For the complete list of every merged pull request in this release, see the full 2024.4.0 changelog.
This is a companion discussion topic for the original entry at https://esphome.io/blog/2024/04/17/esphome-2024-4/
