ESPHOME 2025.2.1 + LD2450 = problem?
Hello all,
Since last update i have a problem that i can’t solve and it’s making me fool
Here is the error:
INFO ESPHome 2025.2.1
INFO Reading configuration /config/esphome/esphome-web-6be67c.yaml...
Failed config
esphome: [source /config/esphome/esphome-web-6be67c.yaml:2]
  Platform missing. You must include one of the available platform keys: libretiny, host, rtl87xx, rp2040, esp8266, bk72xx.
  friendly_name: salon
  on_boot:
    - priority: 100
      then:
        lambda: id(cpu_speed) = ESP.getCpuFreqMHz();
    - priority: -200
      then:
        lambda: |-
          id(zone1_target_exsits).publish_state(false);
          id(zone2_target_exsits).publish_state(false);
          id(zone3_target_exsits).publish_state(false);
here is my code:
esphome:
  friendly_name: "salon"
  on_boot:
    - priority: 100
      then:
        lambda: |-
    - priority: -200
      then:
        lambda: |-
esp32: # Ajout de la section esp32
  board: esp32dev # Spécifiez le type de carte ESP32 que vous utilisez
  framework:
    type: arduino # Spécifiez le framework Arduino
external_components:
  - source:
      type: git
      url: https://github.com/screekworkshop/custom_components_support_for_screek_2a
      ref: main
    components: [esp32, uart]
globals:
  - id: cpu_speed
    type: int
    restore_value: no
    initial_value: '0'
  - id: last_update_ld2450
    type: unsigned long
    restore_value: no
    initial_value: '0'
  - id: init_zone_publish
    type: bool
    restore_value: no
    initial_value: "false"
  - id: last_illuminance
    type: float
    restore_value: no
    initial_value: "-1"
  - id: last_illuminance_timestamp
    type: int
    restore_value: no
    initial_value: "-1"
improv_serial:
#debug:
#  update_interval: 30s
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "h39l7irXnBtlKd4RdGL5LhZzuFAQqn6RZZ2rAe7a5l0="
ota:
  platform: esphome
wifi:
  ssid: "Livebox-B720"
  password: "xxx
  ap:
    ssid: "Esphome-Web-salon"
    password: "1234567890"
captive_portal:
font:
  - file: "gfonts://Roboto"
    size: 25  # Augmentez la taille de la police
spi:
  clk_pin: 22 #clock
  mosi_pin: 23 #din
display:
  - platform: waveshare_epaper
    model: 4.20in
    cs_pin: 21 #CS
    dc_pin: 19 #DC
    busy_pin: 5 #Busy
    reset_pin: 18 #ret
    rotation: 180
    update_interval: 60s
    pages:
      - id: page1
        lambda: |- #it's working here
      - id: page2
interval:
  - interval: 60s
    then:
      - display.page.show_next: epaper_display
      - component.update: epaper_display
web_server:
  port: 80
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
      entity_category: "diagnostic"
      disabled_by_default: True
      icon: mdi:ip-network
    mac_address:
    icon: mdi:information-outline
    entity_category: config
    lambda: |-
      return {"Configure below" };
    update_interval: 1000s
    lambda: |-
    lambda: |-
    lambda: |-
      return {"Zone Exclusion 1" };
    lambda: |-
      return {"Any Presence Config" };
    name: "Target1 Direction"
    icon: mdi:directions
    name: "Target2 Direction"
    name: "Target3 Direction"
    name: "Target1 Position"
    name: "Target2 Position"
    name: "Target3 Position"
number:
    name: "Any Presence Timeout"
    min_value: 0
    max_value: 600
    mode: box
    device_class: duration
    unit_of_measurement: s
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 600
    mode: box
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 600
    mode: box
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 600
    mode: box
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
  # Zone 1
    min_value: -4000
    max_value: 4000
    mode: box
    device_class: distance
    unit_of_measurement: mm
    icon: mdi:arrow-left-bold
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zone1_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    icon: mdi:arrow-right-bold
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    icon: mdi:arrow-up-bold
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    icon: mdi:arrow-down-bold
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
  # Zone 2
    min_value: -4000
    max_value: 4000
    mode: box
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zone2_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
  # Zone 3
    min_value: -4000
    max_value: 4000
    mode: box
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zone3_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
  # Zout1
    min_value: -4000
    max_value: 4000
    mode: box
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zout1_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
binary_sensor:
  - platform: status
    name: "Any Presence"
    device_class: occupancy
    filters:
      - delayed_off: !lambda |-
          if (!id(init_zone_publish) || !id(zone_fn_enable).state) {
            return 0;
          return id(any_presence_timeout).state * 1000.0;
    name: "Zone1 Presence"
    filters:
            return 0;
          return id(zone1_x_timeout).state * 1000.0;
    name: "Zone2 Presence"
    filters:
            return 0;
          return id(zone2_x_timeout).state * 1000.0;
    name: "Zone3 Presence"
    filters:
            return 0;
          return id(zone3_x_timeout).state * 1000.0;
    name: "Zout1 Presence"
    icon: mdi:account-multiple-remove
#radar
  - platform: homeassistant
    entity_id: sensor.esphome_web_6be67c_target1_x
    accuracy_decimals: 0
    internal: true
    entity_id: sensor.esphome_web_6be67c_target1_y
    internal: true
    entity_id: sensor.esphome_web_6be67c_target2_x
    internal: true
    entity_id: sensor.esphome_web_6be67c_target2_y
    internal: true
    entity_id: sensor.esphome_web_6be67c_target3_x
    internal: true
    entity_id: sensor.esphome_web_6be67c_target3_y
    internal: true
    name: "All Target Counts"
    icon: "mdi:counter"
    unit_of_measurement: "targets"
    name: "Zone1 Target Counts"
    icon: "mdi:counter"
    name: "Zone2 Target Counts"
    icon: "mdi:counter"
    name: "Zone3 Target Counts"
    icon: "mdi:counter"
    name: "Zout1 Target Counts"
    icon: mdi:account-multiple-minus-outline
  # Target 1
    unit_of_measurement: 'mm'
    state_class: measurement
    icon: mdi:focus-field-horizontal
    icon: mdi:focus-field-vertical
    accuracy_decimals: 2
    unit_of_measurement: 'm/s'
    device_class: speed
    name: "Target1 Resolution"
  # Target 2
    device_class: speed
    name: "Target2 Resolution"
  # Target 3
    device_class: speed
    name: "Target3 Resolution"
    unit_of_measurement: 'º'
    accuracy_decimals: 1
    icon: mdi:angle-acute
time:
  - platform: sntp
output:
  - platform: gpio
    pin: GPIO12
# code ok and not shown
uart:
  tx_pin:
    number: GPIO17
    mode:
      input: true
      pullup: true
  rx_pin:
    number: GPIO16
    mode:
      input: true
      pullup: true
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
  data_bits: 8
  debug:
    direction: BOTH
    dummy_receiver: True
    after:
     delimiter: [0X55, 0XCC]
    sequence:
      - lambda: |-
          if ((millis() - id(last_update_ld2450)) <= 500) {
            return;
          id(last_update_ld2450) = millis();
          // p1
          int16_t p1_x = (uint16_t((bytes[5] << 8) | bytes[4] ));
          if ((bytes[5] & 0x80) >> 7){
            p1_x -= pow(2, 15);
          }else{
            p1_x = 0 - p1_x;
          int16_t p1_y = (uint16_t((bytes[7] << 8) | bytes[6] ));
          if ((bytes[7] & 0x80) >> 7){
            p1_y -= pow(2, 15);
          }else{
            p1_y = 0 - p1_y;
          int p1_speed = (bytes[9] << 8 | bytes[8] );
          if ((bytes[9] & 0x80) >> 7){
            p1_speed -= pow(2, 15);
          }else{
            p1_speed = 0 - p1_speed;
          int16_t p1_distance_resolution = (uint16_t((bytes[11] << 8) | bytes[10] ));
          // p2
          int16_t p2_x = (uint16_t((bytes[13] << 8) | bytes[12] ));
          if ((bytes[13] & 0x80) >> 7){
            p2_x -=  pow(2, 15);
          }else{
            p2_x = 0 - p2_x;
          int16_t p2_y = (uint16_t((bytes[15] << 8) | bytes[14] ));
          if ((bytes[15] & 0x80) >> 7){
            p2_y -= pow(2, 15);
          }else{
            p2_y = 0 - p2_y;
          int p2_speed = (bytes[17] << 8 | bytes[16] );
          if ((bytes[17] & 0x80) >> 7){
            p2_speed -= pow(2, 15);
          }else{
            p2_speed = 0 - p2_speed;
          int16_t p2_distance_resolution = (uint16_t((bytes[19] << 8) | bytes[18] ));
          // p3
          int16_t p3_x = (uint16_t((bytes[21] << 8) | bytes[20] ));
          if ((bytes[21] & 0x80) >> 7){
            p3_x -=  pow(2, 15);
          }else{
            p3_x = 0 - p3_x;
          int16_t p3_y = (uint16_t((bytes[23] << 8) | bytes[22] ));
          if ((bytes[23] & 0x80) >> 7){
            p3_y -= pow(2, 15);
          }else{
            p3_y = 0 - p3_y;
          int p3_speed = (bytes[25] << 8 | bytes[24] );
          if ((bytes[25] & 0x80) >> 7){
            p3_speed -= pow(2, 15);
          }else{
            p3_speed = 0 - p3_speed;
          int16_t p3_distance_resolution = (uint16_t((bytes[27] << 8) | bytes[26] ));
          bool p1_vaild = (p1_x != 0 || p1_y > 0);
          bool p2_vaild = (p2_x != 0 || p2_y > 0);
          bool p3_vaild = (p3_x != 0 || p3_y > 0);
          // zone exlude 1
          int16_t target_count_in_zone_ex1 = 0;
          int16_t zone_ex1_x_min = id(zone_ex1_x_begin).state;
          int16_t zone_ex1_x_max = id(zone_ex1_x_end).state;
          int16_t zone_ex1_y_min = id(zone_ex1_y_begin).state;
          int16_t zone_ex1_y_max = id(zone_ex1_y_end).state;
          bool p1_zone_ex_enter = false;
          bool p2_zone_ex_enter = false;
          bool p3_zone_ex_enter = false;
          if (id(zone_ex1_enable).state){
            if (p1_vaild){
              if (p1_x >= zone_ex1_x_min && p1_x <= zone_ex1_x_max && p1_y >= zone_ex1_y_min && p1_y <= zone_ex1_y_max){
                  p1_zone_ex_enter = true;
                  target_count_in_zone_ex1 ++;
            if (p2_vaild){
              if (p2_x >= zone_ex1_x_min && p2_x <= zone_ex1_x_max && p2_y >= zone_ex1_y_min && p2_y <= zone_ex1_y_max){
                  p2_zone_ex_enter = true;
            if (p3_vaild){
              if (p3_x >= zone_ex1_x_min && p3_x <= zone_ex1_x_max && p3_y >= zone_ex1_y_min && p3_y <= zone_ex1_y_max){
                  p3_zone_ex_enter = true;
          bool has_target_in_zone_ex1 = (target_count_in_zone_ex1 > 0);
          int16_t all_target_counts = 0;
          if (p1_vaild && !p1_zone_ex_enter){
            all_target_counts ++;
          if (p2_vaild && !p2_zone_ex_enter){
          if (p3_vaild && !p3_zone_ex_enter){
          bool has_target_in_zone_all = (all_target_counts > 0);
          int16_t target_count_in_zone1 = 0;
          bool has_target_in_zone1 = false;
          int16_t target_count_in_zone2 = 0;
          bool has_target_in_zone2 = false;
          int16_t target_count_in_zone3 = 0;
          bool has_target_in_zone3 = false;
          if (id(zone_fn_enable).state){
            // zone 1 check
            int16_t zone1_x_min = id(zone1_x_begin).state;
            int16_t zone1_x_max = id(zone1_x_end).state;
            int16_t zone1_y_min = id(zone1_y_begin).state;
            int16_t zone1_y_max = id(zone1_y_end).state;
              if (p1_x >= zone1_x_min && p1_x <= zone1_x_max && p1_y >= zone1_y_min && p1_y <= zone1_y_max){
                  target_count_in_zone1 ++;
              if (p2_x >= zone1_x_min && p2_x <= zone1_x_max && p2_y >= zone1_y_min && p2_y <= zone1_y_max){
              if (p3_x >= zone1_x_min && p3_x <= zone1_x_max && p3_y >= zone1_y_min && p3_y <= zone1_y_max){
            has_target_in_zone1 = (target_count_in_zone1 > 0);
            // zone 2 check
            int16_t zone2_x_min = id(zone2_x_begin).state;
            int16_t zone2_x_max = id(zone2_x_end).state;
            int16_t zone2_y_min = id(zone2_y_begin).state;
            int16_t zone2_y_max = id(zone2_y_end).state;
              if (p1_x >= zone2_x_min && p1_x <= zone2_x_max && p1_y >= zone2_y_min && p1_y <= zone2_y_max){
                  target_count_in_zone2 ++;
              if (p2_x >= zone2_x_min && p2_x <= zone2_x_max && p2_y >= zone2_y_min && p2_y <= zone2_y_max){
              if (p3_x >= zone2_x_min && p3_x <= zone2_x_max && p3_y >= zone2_y_min && p3_y <= zone2_y_max){
            has_target_in_zone2 = (target_count_in_zone2 > 0);
            // zone 3 check
            int16_t zone3_x_min = id(zone3_x_begin).state;
            int16_t zone3_x_max = id(zone3_x_end).state;
            int16_t zone3_y_min = id(zone3_y_begin).state;
            int16_t zone3_y_max = id(zone3_y_end).state;
              if (p1_x >= zone3_x_min && p1_x <= zone3_x_max && p1_y >= zone3_y_min && p1_y <= zone3_y_max){
                  target_count_in_zone3 ++;
              if (p2_x >= zone3_x_min && p2_x <= zone3_x_max && p2_y >= zone3_y_min && p2_y <= zone3_y_max){
              if (p3_x >= zone3_x_min && p3_x <= zone3_x_max && p3_y >= zone3_y_min && p3_y <= zone3_y_max){
            has_target_in_zone3 = (target_count_in_zone3 > 0);
          // Angle, Position and Direction, idea from walberjunior.
          float p1_angle = 0;
          if (p1_vaild){
            p1_angle = ((float)p1_x / (float)p1_y) * 180 / M_PI;;
          std::basic_string<char> p1_position = "Static";
          if (p1_speed > 0) {
            p1_position = "Moving away";
          } else if (p1_speed < 0) {
            p1_position = "Approaching";
          std::basic_string<char> p1_direction = "None";
          if (p1_x > 0) {
            p1_direction = "Right";
          } else if (p1_x < 0) {
            p1_direction = "Left";
          } else if (p1_y > 0){
            p1_direction = "Middle";
          float p2_angle = 0;
          if (p2_vaild){
            p2_angle = ((float)p2_x / (float)p2_y) * 180 / M_PI;;
          std::basic_string<char> p2_position = "Static";;
          if (p2_speed > 0) {
            p2_position = "Moving away";
          } else if (p2_speed < 0) {
            p2_position = "Approaching";
          std::basic_string<char> p2_direction = "None";
          if (p2_x > 0) {
            p2_direction = "Right";
          } else if (p2_x < 0) {
            p2_direction = "Left";
          } else if (p2_y > 0){
            p2_direction = "Middle";
          float p3_angle = 0;
          if (p3_vaild){
            p3_angle = ((float)p3_x / (float)p3_y) * 180 / M_PI;;
          std::basic_string<char> p3_position = "Static";;
          if (p3_speed > 0) {
            p3_position = "Moving away";
          } else if (p3_speed < 0) {
            p3_position = "Approaching";
          std::basic_string<char> p3_direction = "None";
          if (p3_x > 0) {
            p3_direction = "Right";
          } else if (p3_x < 0) {
            p3_direction = "Left";
          } else if (p3_y > 0){
            p3_direction = "Middle";
          if (id(target1_angle).state != p1_angle){
            id(target1_angle).publish_state(p1_angle);
          if (id(target2_angle).state != p2_angle){
            id(target2_angle).publish_state(p2_angle);
          if (id(target3_angle).state != p3_angle){
            id(target3_angle).publish_state(p3_angle);
# code here not shown
I’m pretty sure here is your problem. You are replacing an ESPHome core component (esp32) by a custom version in a repo that wasn’t updated for 2 year and now it is no longer compatible with the 2025.2 version due to the removal of “old style” Platform Configuration.
I don’t know the reason why you are using this external component, maybe it isn’t necessary anymore, If you really need it, you have to ask the owner of that repo for an update, or create a PR yourself.
I had the same problem and made the following changes and it builds successfully now:
  - source:
      type: git
      ref: main
    components: [uart]
And added the following to the PIN configuration:
output:
  - platform: gpio
    pin:
      number: GPIO12
      ignore_pin_validation_error: true
But why do you still need a custom uart component?
Not 100% sure as I didn’t write the code. Its a question for screek to answer.
You could try not including the external components for UART and see how it goes.
Works great thank you so much !!!
