In this release, we have updated the ESP-IDF framework to version 5.3.2. This version has been thoroughly tested in the background by our development team and is now the default for all configurations using ESP-IDF as the framework.
This version bump brings expanded microcontroller support. ESPHome now officially supports the following ESP32 variants:
- ESP32 - The original ESP32 with dual-core Xtensa LX6
- ESP32-C3 - Single-core RISC-V with Wi-Fi and Bluetooth 5 (LE)
- ESP32-C6 - Single-core RISC-V with Wi-Fi 6, Bluetooth 5 (LE), and Thread/Zigbee (new)
- ESP32-H2 - Single-core RISC-V with Bluetooth 5 (LE) and Thread/Zigbee (new)
- ESP32-S2 - Single-core Xtensa LX7 with Wi-Fi
- ESP32-S3 - Dual-core Xtensa LX7 with Wi-Fi and Bluetooth 5 (LE)
- ESP32-P4 - Dual-core RISC-V high-performance variant (new)
NOTE
The newly supported variants (ESP32-C6, ESP32-H2, ESP32-P4) are still being refined. Some components may not yet be fully compatible with these chips. Additional component updates are planned for ESPHome 2025.7.0.
They also currently only support using the ESP-IDF framework, and do not work with the Arduino framework in this release.
Please check our Pull Requests for the latest compatibility status before reporting issues with these new variants.
This release is the last release which will support ESP-IDF 4.x versions; in the July release (2025.7.0) we will bump the default Arduino version to 3.1.3, which is now built on IDF 5.x and, as such, ESPHome will no longer require ESP-IDF 4.x support to maintain compatibility with Arduino. Please see our developer blog for more details.
WARNING
Device configurations held back on ESP-IDF 4.x are unlikely to compile with the next ESPHome release (2025.7.0).
You can continue to use older versions of ESPHome, but you’ll need to ensure your device configurations are using IDF 5.x if you wish to upgrade to 2025.7.0 or later releases of ESPHome.
With the ESP-IDF 5.3.2 update, we’ve introduced basic OpenThread support for ESP-IDF based configurations. This exciting addition enables ESP32-C6 and ESP32-H2 devices to join Thread networks, expanding your connectivity options beyond traditional Wi-Fi and Ethernet.
Your ESPHome devices can now connect to Thread networks and communicate with Home Assistant through the Native API, provided you have:
- Thread support enabled in Home Assistant
- An OpenThread border router configured and running on your network
Thread is designed as a low-power, low-bandwidth networking protocol. It’s specifically optimized for:
- IoT devices with minimal data transmission needs
- Battery-powered or energy-efficient applications
- Mesh networking scenarios
- ESPHome does not yet support Thread “Sleepy End Device” mode (low-power sleep functionality)
- Not recommended for applications requiring high-frequency sensor data transmission
- Best suited for simple control and monitoring use cases
Think of Thread support as providing you with a third networking option alongside Wi-Fi and Ethernet, particularly valuable for ESP32-C6 and ESP32-H2 deployments in mesh network environments.
Starting with ESPHome 2025.6.0, Python 3.10 or higher is required to run ESPHome. This change enables us to:
- Utilize modern Python features and improvements
- Remove legacy compatibility code that was needed for older Python versions
- Maintain a more secure and efficient codebase
Python 3.9 reaches its end of life in October 2025, making this upgrade both timely and necessary for long-term security and maintainability.
Installation Method Action Required Home Assistant Add-on No action needed - Already uses Python 3.12 Container Images (Docker) No action needed - Already uses Python 3.12 Direct Installation (pip) Ensure Python 3.10+ is installed before running pip install -U esphomeWARNING
If you’re running ESPHome directly on your machine with Python 3.9 or older, running pip install -U esphome
will not upgrade beyond version 2025.5.2. You must upgrade your Python installation first.
This release includes extensive performance improvements across multiple areas of ESPHome. Our optimization efforts focus on three key areas:
Native API Speed Enhanced Native API performance for faster communication between ESPHome devices and Home Assistant.
Memory Footprint Reduction Significant RAM usage optimizations to improve stability and allow for more complex configurations, especially on memory-constrained devices.
Flash Storage Efficiency Reduced compiled firmware size, leaving more flash storage available for your applications and OTA updates.
These optimizations are part of an ongoing effort to make ESPHome more efficient and reliable. More performance improvements are planned for future releases.
Great news for Bosch BME68x BSEC2 sensor users! Bosch has merged and released a community contribution to their BSEC2 library that removes the Arduino framework dependency. This improvement means:
- Better ESP-IDF compatibility - BME68x sensors now work seamlessly with ESP-IDF based configurations
- Reduced dependencies - Cleaner builds without unnecessary Arduino components
- Improved reliability - More stable sensor operation across different ESP32 variants
This change makes the BME68x environmental sensors more versatile and easier to integrate into ESP-IDF projects, continuing ESPHome’s move toward framework flexibility.
For the complete list of every merged pull request in this release, see the full 2025.6.0 changelog.
This is a companion discussion topic for the original entry at https://esphome.io/blog/2025/06/18/esphome-2025-6/
