111lisu
(Mariusz)
April 3, 2024, 10:45pm
1
Has anyone had the opportunity to measure the ACS758 current?
- platform: adc
name: "Prąd Silników trackera ADC0"
update_interval: 250 ms
# unit_of_measurement: "A"
pin: GPIO36
filters:
- median:
window_size: 8
send_every: 2
send_first_at: 2
# attenuation: auto
# accuracy_decimals: 3
I forget that ESP32 measures 0-1V, but I practically see no change in voltage
I found How To Measure Current Using XIAO ESP32 And ACS758 Sensor | A Step By Step Guide - Open Green Energy
and I don’t see any pullup resistor and the voltage is around 0.4V
The question is how to define it
const float VOLTAGE_REFERENCE = 3.3; // Change to 5 if using 5V VCC
const float SENSITIVITY = 0.04; // 40mV/A -Sensitivity of ACS758 (check the datasheet for your ACS758 model)
const float OFFSET_VOLT = VOLTAGE_REFERENCE / 2; // Zero-current output voltage ( Offset Voltage)
snippem
(marco)
May 20, 2025, 7:04pm
2
Hi did you ever found a solution for this sensor ?
caladrien
(Caladrien)
January 27, 2026, 9:34pm
3
You could do it like this:
# ACS758 Rohspannung (ADC)
- platform: adc
pin: GPIO34
attenuation: 12db
update_interval: ${adc_update}
internal: true
filters:
- sliding_window_moving_average:
window_size: 10
send_every: 1
# Strom aus ACS758 (A)
update_interval: ${templ_update}
accuracy_decimals: 2
device_class: current
state_class: measurement
internal: true
lambda: |-
return id(acs758_voltage).state;
filters:
- calibrate_linear:
- 1.00000 -> -19.63
- 1.86233 -> 0.00
- 2.50000 -> 14.52
I like to have my adc pin and the resulting value out of it in separat sensors. You could also put the calibrate_linear: directly into the platform: adc sensor.
Basicly a good start is the following:
- calibrate_linear:
- 0.65 -> -25
- 1.65 -> 0.00
- 2.65 -> 25
Record some statistics with a working and calibrated sensor and give both plots to an AI and it will solve it for you.
With attenuation: 12db you can measure up to 3v3 on the adc pin.
