EspHome action not worked
Hello. Made a switch from relay, esp8266 and buttons. I can turn on the light through the Home Assistant, but there is no button. If I connect from the EspHome Dashboard and look at the logs, I see a message like “light_button2 ': Sending state ON”, but relay(and status in HA too) not react. Please help. Here is the config:
output:
  - platform: gpio
    pin: 2
light:
  - platform: binary
    output: gpio_22
binary_sensor:
  - platform: gpio
    pin: 0
    on_click:
      min_length: 200ms
      then:
        - light.toggle: light_2
When you press the button you have on the binary sensor does the log show the light_2 toggling both ‘ON’ and ‘OFF’?
Thanks for answer!
I see that:
[22:39:15][D][binary_sensor:036]: 'light_button2': Sending state ON
[22:39:15][D][binary_sensor:036]: 'light_button2': Sending state OFF
Give the gpio output a name and it will show up in home assistant. If you only use id it is internal to the ESP only.
Likewise for the binary sensors (if you actually want them in home assistant).
Yes, as tom_i said. I hadn’t spotted that. You need something like:
switch:
  - platform: gpio
    pin: 2
binary_sensor:
  - platform: gpio
    pin: 0
    name: "Light Button 2"
    on_click:
      min_length: 200ms
      then:
        - switch.toggle: light_2
Then, in HA integrations, you’ll be able to see your entities.
