ESPhome Adafruit ESP32-S3 Reverse TFT Feather
I got ESPhome working with the Adafruit ESP32-S3 Reverse TFT Feather. The trick is the on_boot, that has to be on sooner than the “platform: st7789v” can turn it on.
substitutions:
  devicename: displayer
  prettyname: "Displayer"
  mqttroot: "displayer"
  area: "EE Lab"
esphome:
  friendly_name: ${prettyname}
  on_boot:
    priority: 1000
    then:
      #  The following lambda turns on the TFT/I2C Power
      - lambda: |-
          pinMode(7, OUTPUT);
          digitalWrite(7, HIGH);
          delay(10);
esp32:
  board: adafruit_feather_esp32s3_tft
  variant: esp32s3
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "9oMpk+/eAp2XkL90TwPdRNWd+s="
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: !secret wifi_ssid
web_server:
  port: 80
captive_portal:
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_gray
    red: 50%
    green: 50%
    blue: 50%
font:
  - file: "gfonts://Roboto"
binary_sensor:
  - platform: status
i2c:
  sda: 3
  scl: 4
  scan: true
  - platform: sht4x
    temperature:
    humidity:
    update_interval: 5s
time:
  - platform: homeassistant
spi:
  clk_pin: GPIO36
  mosi_pin: GPIO35
  miso_pin: GPIO37
  interface: software # force_sw: true
display:
  - platform: st7789v
    model: TTGO TDisplay 135x240
    backlight_pin: GPIO45
    rotation: 90
    cs_pin: GPIO42
    dc_pin: GPIO40
    reset_pin: GPIO41
    update_interval: 1s
    lambda: |-
      it.rectangle(0,  0, it.get_width(), it.get_height(), id(my_blue));
      it.rectangle(0, 25, it.get_width(), it.get_height(), id(my_blue));
      it.print(5, 5, id(font20), id(my_yellow), TextAlign::TOP_LEFT, "HELLO");
      if (id(system_status).state) {
        it.print(235, 5, id(font20), id(my_green), TextAlign::TOP_RIGHT, "Online");
      else {
        it.print(235, 5, id(font20), id(my_red), TextAlign::TOP_RIGHT, "Offline");
      it.printf((240 / 2), (140 / 6) * 1 + 5, id(large), id(my_green), TextAlign::TOP_CENTER, "%.1f °C", id(thermostat_temp).state);
      it.printf(5, (140 / 6) * 3 + 10, id(medium), id(my_green), TextAlign::TOP_LEFT, "%.1f °F", id(thermostat_temp).state*9/5+32);
      it.printf(235, (140 / 6) * 3 + 10, id(medium), id(my_blue), TextAlign::TOP_RIGHT, "%.1f%%",  id(thermostat_humidity).state);
Use a power_supply component with enable_on_boot: true for that.
