Hi all, I’m having my esphome running on a NodeMCU ESP32 to control a smart lock for auto-lock & remote unlock. Everything works well up until I added an interval HTTP request to allow for remote unlock.
Problem: The ESP32 would always show a barebone web server layout once every few hours, which I guess is a safe mode? In this state, I can’t do any OTA either from a PC (error timeout) or from the web interface (success, but still in barebone mode). Instead, the firmware can get back on its own if I reboot the board.
For the remote unlock part, I’m using Telegram bot to access an “/open” command via polling. I have an interval check to retrieve the latest message.
The strange thing is that I already disabled safe_mode component just to make sure, but it still happens regardless, so I’m not sure if the condition here is “safe mode” or not. Here’s the screenshot of the web server:
One thing I noticed is that the HTTP request inside the polling interval can take a while, it would always warn about ~2000ms execution time. Maybe that’s related?
10:29:21 [W] [component:453] interval took a long time for an operation (3964 ms)
10:29:21 [W] [component:456] Components should block for at most 30 ms
10:29:21 [W] [component:453] api took a long time for an operation (3970 ms)
In any case, my code is below. Any help is appreciated, thanks! Do note that I’ve switched my board around and the issue is consistent across all of them.
substitutions:
telegram_token: !secret telegram_bot_token
telegram_chat: !secret telegram_chat_id
use_battery: true
# No battery: Auto-close on power.
# Battery: Close on door sensor.
door_open_notify_time: 15
# In seconds
esphome:
on_boot:
- priority: 550
then: # No-battery mode: Power connected = closed
- if:
condition:
lambda: return ${0 if use_battery else 1};
then:
- button.press: door_close
esp32:
board: nodemcu-32s
framework:
type: esp-idf
sdkconfig_options:
CONFIG_LWIP_MAX_SOCKETS: '16'
safe_mode:
disabled: true
# Enable logging
logger:
logs:
# Prevent component from spamming the logs
http_request.idf: ERROR
# Enable Home Assistant API
api:
password: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: "Ab-Apart"
fast_connect: true
ap:
ssid: "Smart-Door Fallback Hotspot"
password: !secret ap_password
captive_portal:
http_request:
time:
- platform: sntp
timezone: Europe/Berlin
on_time_sync:
- if:
condition:
lambda: return id(pending_close_time) == true;
then:
# Update the previously pending close time
- globals.set:
value: !lambda |-
time_t currTime = id(time_now).now().timestamp;
return currTime;
- globals.set:
value: "false"
globals:
- id: global_open_time
type: time_t
restore_value: true
initial_value: ""
- id: global_close_time
type: time_t
restore_value: true
initial_value: ""
- id: last_update_id
type: int
restore_value: true
initial_value: "0"
- id: pending_close_time
type: bool
restore_value: false
initial_value: "false"
- id: door_open_notify_sent
type: bool
- id: telegram_poll_counter
type: int
initial_value: "0"
# UI Controls
number:
name: Servo Rotation Duration
min_value: 1
restore_value: true
initial_value: 4.5
max_value: 6
step: 0.5
optimistic: true
web_server:
sorting_group_id: sorting_group_servo_settings
min_value: -100
initial_value: 0
max_value: 100
step: 1
optimistic: true
web_server:
set_action:
# Detach if given value is 0
then:
- servo.write:
level: !lambda 'return x / 100.0;'
- if:
condition:
lambda: 'return x == 0;'
then:
- delay: !lambda 'return 50;'
- servo.detach:
- logger.log:
format: "Servo detached"
button:
# Most components have REST API, read more: https://esphome.io/web-api/#api-rest
# Equivalent: http://smart-door.local/button/open/press (using name, not id)
web_server:
sorting_group_id: sorting_group_door_actions
on_press:
# Move servo until the door is opened, or timeout
if:
condition: # Only if not currently moving
lambda: 'return id(servo_number).state == 0;'
then:
- globals.set:
value: !lambda |-
return currTime;
- number.set:
value: -100
- wait_until:
condition:
binary_sensor.is_on: door_is_open
timeout: !lambda 'return id(servo_duration).state * 1000 + 1000;'
# Continue opening a bit after the door is opened
- delay: !lambda 'return 1500;'
- number.set:
value: 0
web_server:
on_press:
# Only trigger closing if the door is not currently opening
- if:
condition:
time.has_time:
then:
- globals.set:
value: !lambda |-
return currTime;
else:
- globals.set:
value: "true"
- if:
condition:
lambda: 'return id(servo_number).state >= 0;'
then:
- number.set:
value: 100
- delay: !lambda 'return id(servo_duration).state * 1000;'
- number.set:
value: 0
web_server:
on_press:
then:
- number.set:
value: 0
# Hidden button to trigger status message (called from interval)
internal: true
on_press:
then:
- http_request.post:
url: "https://api.telegram.org/bot${telegram_token}/sendMessage"
request_headers:
Content-Type: application/json
json: |-
std::string status_emoji = id(door_is_open).state ? "🟥" : "🟩";
std::string status_text = id(door_is_open).state ? "OPEN" : "CLOSED";
// ... etc.
interval:
- interval: 1s
then:
# Check if door still opens: Door is open and more than 5 seconds since
- if:
condition:
lambda: return id(door_is_open).state && !id(door_open_notify_sent) && id(time_now).now().timestamp - id(global_open_time) > ${door_open_notify_time};
then:
- globals.set:
value: "true"
- logger.log:
format: "Door is opened for more than ${door_open_notify_time} seconds"
request_headers:
json: |-
std::string message = "*Warning: Door is OPEN 🟥* \n";
root["chat_id"] = ${telegram_chat};
root["text"] = message;
root["parse_mode"] = "Markdown";
# Poll Telegram for new messages every 1 second (or 5s when door is closed). This allows faster detection of open => close.
- lambda: |-
// Increment counter
id(telegram_poll_counter) = id(telegram_poll_counter) + 1;
// If door is open, only poll every 5 seconds (every 5th trigger)
// If door is closed, poll every second
bool should_poll = (!id(door_is_open).state) || (id(telegram_poll_counter) >= 5);
if (should_poll) {
id(telegram_poll_counter) = 0; // Reset counter
- if:
condition:
lambda: return id(telegram_poll_counter) == 0;
then:
- http_request.get:
url: "https://api.telegram.org/bot${telegram_token}/getUpdates?offset=-1&limit=1"
capture_response: true
on_response:
- if:
condition:
lambda: return response->status_code == 200;
then:
- lambda: |-
json::parse_json(body, [](JsonObject root) -> bool {
// code here
else:
- logger.log:
format: "Telegram API error: %d"
args: ['response->status_code']
text_sensor:
# Just for displaying globals in web UI
name: Door Last Closed
lambda: |-
char str[30];
time_t currTime = id(global_close_time);
strftime(str, sizeof(str), "%Y-%m-%d %H:%M", localtime(&currTime));
return std::string(str);
update_interval: 30s
name: Door Last Opened
lambda: |-
char str[30];
time_t currTime = id(global_open_time);
# Hardwares
binary_sensor:
# Optional, only when using a battery (always on)
- platform: gpio
name: Door is Open
device_class: door
pin:
number: GPIO12
mode:
input: true
pullup: true
# Means door is closed on release
filters:
- delayed_off: 100ms
on_release:
then: # Low = closed. Auto-lock when door is closed
- if:
# If previously we sent open warning, and not it's closed, then send new status
condition:
lambda: return id(door_open_notify_sent);
then:
- globals.set:
value: "false"
- button.press: send_status_message
- if:
condition:
lambda: return ${1 if use_battery else 0};
then:
- platform: gpio
device_class: door
pin:
number: GPIO14
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on_off: 100ms
on_press:
then: # High = pressed. Open the door
- button.press: door_open
servo:
- id: servo_hw
output: servo_pwm_output
output:
- platform: ledc
pin: GPIO13
frequency: 50Hz
web_server:
version: 3
port: 80
sorting_groups:
- id: sorting_group_door_actions
sorting_weight: 10
- id: sorting_group_servo_settings
name: "Servo Settings"
sorting_weight: 20
