ESPHome and a dc motor
Hi all
I am trying to get a lava wave machine into home assistant, but its only to turn it on and off via a pir in my office so its only moving when I am in the office, the details are it runs off a 1.5v battery which I will remove and wire to the D1 mini, D1 mini 3v converted to 1.5v which is fine but how do I put this into ESPHome as a switch as I only need power 1.5v and ground to run the motor? how do I get a on off switch?. any help would be great many thanks
thank you this has helped I did look at this but just needed a start point, found a video that got me started did not know that D pins provide power also so set D2 as switch and its working
Hi, I’m trying to do something similar. Would you mind sharing your ESPHome yaml and how you wired everything up. My motor simply will not turn (it does work) and I’m missing something fundamentally, staring me in the face and its driving me nuts.
