ESPHome and HLK-LD2410C errors during flashing
Hi.
I’m trying to flash the nodemcu for using it with HLK-LD2410C, but I cannot prepare the proper YAML file.
esphome:
  friendly_name: ESPHome Web f1b6f9
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "4sBk/0PU+rrRt4juyEM1a79FXv3cjvOA0vh3gGyNRps="
ota:
wifi:
  ssid: xxxx
  password: xxxx
  ap:
    ssid: "Esphome-Web-F1B6F9"
    password: "yxc33AZw0gho"
# ESPHome Example configuration entry
uart:
  tx_pin: TX
  rx_pin: RX
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
button:
  - platform: restart
    entity_category: config
    internal: false
ld2410:
  - timeout: 1s
    max_move_distance: 6m
    max_still_distance: 0,75m
    g0_move_threshold: 50
    g0_still_threshold: 0
    g1_move_threshold: 50
    g1_still_threshold: 0
    g2_move_threshold: 40
    g2_still_threshold: 40
    g3_move_threshold: 30
    g3_still_threshold: 40
    g4_move_threshold: 20
    g4_still_threshold: 30
    g5_move_threshold: 15
    g5_still_threshold: 30
    g6_move_threshold: 15
    g6_still_threshold: 20
    g7_move_threshold: 15
    g7_still_threshold: 20
    g8_move_threshold: 15
    g8_still_threshold: 20
  - platform: ld2410
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
platform: ld2410
    on_press:
    uart.write: "0xA3 0x00 nullptr 0"
    delay: 3s
Everytime I have an information that the mapping is not allowed in the following part:
platform: ld2410
    on_press:
    delay: 3s
I’ve used the online YAML validator and found that there is a bad indentation of a mapping entry, but I also cannot solve that problem…
Could you take a look into my code?
platform: ld2410
    on_press:
        delay: 3s
thank you.
there is next result from the log:
INFO ESPHome 2023.8.2
INFO Reading configuration /config/esphome/esphome-web-f1b6f9.yaml...
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
  in "/config/esphome/esphome-web-f1b6f9.yaml", line 90, column 9:
The ESPHome component for the LD2410 has been recently updated and the format of some of the YAML has changed so it may be best for you to follow the config documented here:
Also with your formatting above, the values after platform has been indented 4 spaces. Is that right or should it be:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
  - platform: ld2410
    on_press:
      delay: 3s
