I am stuck trying to process a json string in ESPhome. Here the config:
esphome:
friendly_name: esphome-tibber-com
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "..."
ota:
- platform: esphome
password: "..."
# Example configuration entry
wifi:
ssid: ...
password: ...
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
font:
- file: "https://github.com/IdreesInc/Monocraft/releases/download/v3.0/Monocraft.ttf"
# gfonts://family[@weight]
- file: "Eight-Bit-Dragon.ttf"
- file: "pixelmix.ttf"
- platform: homeassistant
entity_id: sensor.electricity_price_gaddgrand_4
internal: true
entity_id: sensor.esphome_tibber_brigthness
internal: true
entity_id: sensor.develco_zhemi101_instantaneous_demand
internal: true
entity_id: sensor.tesla_usd
internal: true
globals:
- id: page
type: int
initial_value: "1"
- id: next_10_hours_prices
type: float[10]
initial_value: '{0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0}'
- id: next_10_hours_levels
type: std::vector<std::string>
initial_value: '{"", "", "", "", "", "", "", "", "", ""}'
- id: debug_mode
type: bool
initial_value: 'true'
text_sensor:
entity_id: sensor.tibber_electricity_price
attribute: current
display:
- platform: max7219digit
cs_pin: GPIO5
num_chips: 4
intensity: 0
lambda: |-
switch (id(page)){
case 1:
// Print the current time
it.printf(0, 0, id(pixel_8), "%.2f", id(tibber_sensor).state);
it.line(24, 0, 24, 7);
it.line(25, 4, 25, 7);
it.line(26, 5, 26, 7);
it.line(27, 6, 27, 7);
it.line(28, 2, 28, 7);
it.line(29, 1, 29, 7);
it.line(30, 1, 30, 7);
break;
case 2:
it.printf(0, 0, id(pixel_8), "%.0fW", id(tibber_demand).state);
break;
case 3:
it.printf(0, 0, id(pixel_8), "%.2f", id(tesla_usd).state);
break;
auto json_str = id(tibber_prices).state;
auto root = json::parse(json_str);
interval:
- interval: 5s
then:
- lambda: |-
id(page) = (id(page) + 1);
if (id(page) > 3) {
id(page) = 1;
When compiling i get following error:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/esphome-tibber-com.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-tibber-com (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Update @ 2.0.0
|-- noise-c @ 0.1.6
|-- SPI @ 2.0.0
Compiling .pioenvs/esphome-tibber-com/src/main.cpp.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ssse3.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_hash/sha512/cp/hash_sha512_cp.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_hash/sha512/hash_sha512.c.o
/config/esphome/esphome-tibber-com.yaml: In lambda function:
/config/esphome/esphome-tibber-com.yaml:120:19: error: 'json' has not been declared
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/esphome-tibber-com/libbf6/libsodium/crypto_pwhash/argon2/argon2-core.c.o
*** [.pioenvs/esphome-tibber-com/src/main.cpp.o] Error 1
Seems like json::parse_json can’t be found.
What am I doing wrong?
Frank
