This is about configuring mqtt / Mosquitto on Home Assistant. For some reason, Mosquitto logs has these lines repeating every 5 s (with different port):
2026-06-19 10:33:41: New connection from [MYIP]:51593 on port 1883.
2026-06-19 10:33:41: Client esphome-dashboard-ccc8f773b932 [MYIP]:51593 disconnected: not authorised.
Also ESPHome Builder App logs show one of these (not repeating) which looks very related:
2026-06-18 11:47:36.732 WARNING (MainThread) [esphome_device_builder.controllers._device_mqtt_monitor] MQTT broker [MYIP]:1883 unreachable ([Errno 111] Connection refused) — reconnecting in 5s
(Where [MYIP] is my local IP address)
The things I have done before noticing these:
- install ESPHome Builder app
- install Mosquitto App
- install mqtt integration
- create mqtt user
- set mqtt integration use the mqtt user+password
What might be causing this and how can I fix?
Some ESPHome configuration seems to be off?
