ESPHome api connection issues
I have an D1 Mini ESP32 module connected to several MCP23017s over I2C and I’m constantly getting the following lines in the log file, also all entities show in HA as ‘Unavailable’ but all the inputs and outputs work properly.
[20:38:41][D][api.connection:153]: Home Assistant 2021.9.7 (10.0.4.10) requested disconnected
[20:38:42][D][api:095]: Accepted 10.0.4.10
[20:38:42][D][api.connection:727]: Home Assistant 2021.9.7 (10.0.4.10): Connected successfully
[20:38:50][D][api.connection:153]: Home Assistant 2021.9.7 (10.0.4.10) requested disconnected
[20:38:50][D][api:095]: Accepted 10.0.4.10
[20:38:51][D][api.connection:727]: Home Assistant 2021.9.7 (10.0.4.10): Connected successfully
[20:38:57][D][api.connection:153]: Home Assistant 2021.9.7 (10.0.4.10) requested disconnected
[20:38:57][D][api:095]: Accepted 10.0.4.10
[20:38:57][D][api.connection:727]: Home Assistant 2021.9.7 (10.0.4.10): Connected successfully
Any assistance would be greatly appreciated as I’ve never seen this before.
Same issue here…only with ESP device
