ESPHOME API Password deprecated -- but how about no password?
The latest release notes mention API Password deprecated in favor of encryption keys (note here).
I have no password for the API. I’m more paranoid than most, but it’s a private network, and wifi is already encrypted, so I was never concerned. And I get encryption keys versus password, not complaining.
I assumed this “no password” would go away also, but I got no warning when I compiled with 2025.10.1.
I’m not against moving to encryption, I just don’t care (in what I think is an informed way) and won’t go unless I need to.
So… is the password deprecation going to include “no password” also?
If so, you may want to extend the warning message, as I did not see it.
If not… thanks.
Linwood
That’s default and recommended. Just remove the whole option.
" * password (Optional, Deprecated, string): The password to protect the API Server with. Defaults to no password. It is recommended to use the encryptionkey above instead of the the password."
Just set it once, as it’s used for Esphome - HA communication, you will not be bothered with is again.
You can even use the same key for every device if you want.
I apologize for not understating…
You are saying that having no password is recommended?
And in particular is not deprecated?
Yes
“Deprecation is the discouragement of use of something human-made, such as a linguistic term, a proper name, a feature, design, functionality, piece of code, or practice.”
