Product: Nutridays KT630LB Bluetooth Kitchen Scale
Brief Description:
ESPHome configuration for Nutridays KT630LB Bluetooth kitchen scale. The device connects via BLE to read weight measurements in real-time. Scale has 1g resolution and sends data packets with 24-bit weight values. ESP32-C3 automatically connects when scale is detected, reads weight data, and publishes to Home Assistant with 1-second throttle. Includes connection status monitoring and automatic disconnect when scale goes out of range.
esphome:
friendly_name: kitchenscale
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
logger:
level: INFO
api:
encryption:
key: "YOUR_ENCRYPTION_KEY"
ota:
- platform: esphome
password: "YOUR_OTA_PASSWORD"
wifi:
ssid: "YOUR_WIFI_SSID"
password: "YOUR_WIFI_PASSWORD"
manual_ip:
static_ip: 192.168.x.x
gateway: 192.168.x.x
subnet: 255.255.255.0
dns1: 192.168.x.x
output_power: 10dB
fast_connect: true
passive_scan: false
globals:
- id: kitchenscale_weight_raw
type: int
restore_value: no
initial_value: '0'
- id: kitchenscale_ble_connected
type: bool
restore_value: no
initial_value: 'false'
esp32_ble_tracker:
scan_parameters:
interval: 1200ms
window: 400ms
active: false
ble_client:
- mac_address: "XX:XX:XX:XX:XX:XX"
auto_connect: false
on_connect:
then:
- lambda: |-
id(kitchenscale_ble_connected) = true;
on_disconnect:
then:
- lambda: |-
id(kitchenscale_ble_connected) = false;
interval:
- interval: 3s
then:
- text_sensor.template.publish:
state: !lambda |-
if (id(kitchenscale_ble_connected)) {
return "Connected";
} else {
return "Waiting";
- lambda: |-
static uint64_t last_connect_attempt = 0;
uint64_t now = millis();
if (!id(kitchen_scale)->connected() &&
id(kitchenscale_detected).state &&
(now - last_connect_attempt > 10000)) {
last_connect_attempt = now;
id(kitchen_scale)->connect();
if (id(kitchen_scale)->connected() &&
!id(kitchenscale_detected).state) {
static uint64_t disconnect_timer = 0;
if (disconnect_timer == 0) {
disconnect_timer = now;
} else if (now - disconnect_timer > 5000) {
id(kitchen_scale)->disconnect();
} else {
- platform: ble_client
type: characteristic
name: "Kitchen Scale Raw Data"
internal: true
ble_client_id: kitchen_scale
service_uuid: '0000ffb0-0000-1000-8000-00805f9b34fb'
characteristic_uuid: '0000ffb2-0000-1000-8000-00805f9b34fb'
notify: true
lambda: |-
if (x.size() >= 20 && x[0] == 0xAC && x[1] == 0x40) {
uint32_t weight_raw = ((uint32_t)x[4] << 16) | ((uint32_t)x[5] << 8) | x[6];
id(kitchenscale_weight_raw) = weight_raw;
float weight_grams = (float)weight_raw / 1000.0;
id(kitchen_weight).publish_state(weight_grams);
return {};
name: "Kitchen Scale Weight"
icon: "mdi:scale"
unit_of_measurement: "g"
accuracy_decimals: 0
device_class: weight
state_class: measurement
filters:
- throttle: 1s
lambda: 'return id(kitchenscale_weight_raw) / 1000.0;'
binary_sensor:
- platform: status
- platform: ble_presence
name: "Kitchenscale Detected"
text_sensor:
icon: 'mdi:bluetooth'
lambda: |-
return {"Connected"};
} else {
return {"Waiting"};
- platform: wifi_info
ip_address:
ssid:
mac_address:
Home Assistant integration for Nutridays KT630LB kitchen scale.
