ESPHome: button : template : how to pass variables?
I’ve implemented Atlas Scientific EZO ORP and pH sensor boards and its all mostly figured out. Both boards allow calibration and I’d like to have on Home Assistant (HA) dashboard a button to push (with calibration standard) so when I emerse probe into calibration standard just push button and set. Right now I have a button but had to hard code it for a particular standard value. I’d like to pass a value but it looks like ESPHome button/Template doesn’t support passed variables. Is that true or is there a way around it? Thanks in advance.
button:
  • platform: template
    name: “Orp Calibration”
    on_press:
    • logger.log: “Button Pressed”
    • lambda: id(orp_ezo).send_custom(“Cal,225”);
orp cal button press
Depends on where you are going to get the value
button:
  platform: template
  on_press:
    - logger.log: “Button Pressed”
    - lambda: |-
        id(gloabal_var) = id(something).state;
or
    - lambda: |-
        id(gloabal_var) = id(something);
But maybe you can use a number template:
number:
    optimistic: true
    min_value: 0
    max_value: 100
    step: 1
    restore_value: true
So you can use something like this:
    lambda: |-
        return (id(calibration_number).state * 3.1415);
Thanks will try those methods
