Hi all,
I think I’m losing my mind.
I had a test circuit with an ESP32 and a 10kOhm NTC that worked fine. So I had a PCB made to attach a couple more NTCs, confirmed with the old configuration that it still worked and started adapting the code for more sensors (of course I didn’t make a backup…).
Now the ESP32 reads the correct voltage, calculates the correct resistance and reports a temperature that’s not even remotely close to correct. I don’t understand what is going on.
I have verified the voltage and resistance with a multimeter and manually calculating it gives me the expected value of ~21 °C. Reference resistor is also actually 10kOhm.
Here is my current configuration:
esphome:
friendly_name: ESP32 Thermometer Warmwasser
min_version: 2025.9.0
name_add_mac_suffix: false
esp32:
variant: esp32
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.1.205
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.1.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
captive_portal:
switch:
- platform: gpio
pin: GPIO32
interval:
- interval: 1s
then:
- switch.turn_on: ntc_vcc_5
- component.update: ntc_5
- switch.turn_off: ntc_vcc_5
- platform: ntc
sensor: ntc_5
calibration:
b_constant: 3590
reference_temperature: 25°C
reference_resistance: 10kOhm
name: NTC Temperature 5
# Example source sensors:
- platform: resistance
sensor: ntc_5
configuration: DOWNSTREAM
resistor: 10kOhm
name: Resistance Sensor 5
# ADC sensors
- platform: adc
pin: GPIO33
attenuation: auto
update_interval: 1s
filters:
- sliding_window_moving_average:
window_size: 60
send_every: 30
send_first_at: 30
Help? ![]()
Once again I wish I could just slap down some C-code.
