Esphome can't compile my yaml for a esp32-C3
About two esphome updates ago I notinced that I cannot update my ESP32-C3 devices. I kinds ashugged it off as I was happy with what was working, now I want to make changes I get thi s error:
Using Python 3.12.10 environment at: /root/.platformio/penv/.espidf-5.5.4
Reading CMake configuration…
– git rev-parse returned ‘fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).’
– Minimal build - OFF
– The C compiler identification is unknown
– The CXX compiler identification is unknown
– The ASM compiler identification is GNU
– Found assembler: /data/cache/platformio/packages/toolchain-riscv32-esp/bin/riscv32-esp-elf-gcc
– Detecting C compiler ABI info
– Detecting C compiler ABI info - failed
– Check for working C compiler: /data/cache/platformio/packages/toolchain-riscv32-esp/bin/riscv32-esp-elf-gcc
– Check for working C compiler: /data/cache/platformio/packages/toolchain-riscv32-esp/bin/riscv32-esp-elf-gcc - broken
– Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/tool-cmake/share/cmake-4.0/Modules/CMakeTestCCompiler.cmake:67 (message):
The C compiler
"/data/cache/platformio/packages/toolchain-riscv32-esp/bin/riscv32-esp-elf-gcc"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: '/data/build/dogbowl/.pioenvs/dogbowl/CMakeFiles/CMakeScratch/TryCompile-uWrb2X'
Run Build Command(s): /data/cache/platformio/packages/tool-ninja/ninja -v cmTC_b629c
[1/2] /data/cache/platformio/packages/toolchain-riscv32-esp/bin/riscv32-esp-elf-gcc   @"/data/build/dogbowl/.pioenvs/dogbowl/toolchain/cflags" -o CMakeFiles/cmTC_b629c.dir/testCCompiler.c.obj -c /data/build/dogbowl/.pioenvs/dogbowl/CMakeFiles/CMakeScratch/TryCompile-uWrb2X/testCCompiler.c
FAILED: [code=1] CMakeFiles/cmTC_b629c.dir/testCCompiler.c.obj
Assembler messages:
Fatal error: invalid -march= option: `rv32imafdc_zicsr_zifencei'
ninja: build stopped: subcommand failed.
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
/data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:601 (__project)
CMakeLists.txt:3 (project)
========================== [FAILED] Took 4.30 seconds ==========================
Here is the first few lines of my yaml:
esphome:
friendly_name: dogbowl
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
I cleaned the build files
I changed to arduino
Tried to force it to a specific version 5.1.4
Tried these commands from Claude
rm -rf /data/cache/platformio/packages/toolchain-riscv32-esp
rm -rfrm -rf /data/build/dogbowl
All with the same result. Is there a fix for this??? I only have two of these little guys but I want to use them for future projects.
Thanks for any ideas!
Blockquote
What version of the ESPHome Device Builder App are you using? 2026.4.3 is current. Maybe try to restart it?
edit:
Thanks mightybosstone,
I had run the clear build files but was leary of running the Clear All Files. Not anymore that fixed the issue. ESP home redownloaded everything and I was in business. Thanks for the nudge!
Ed
