I recently set up the new ESPHome CC1101 component on an ESP32 DevKit board and wanted to share some findings that may help others.
Hardware
ESP32 DevKit VROOM
CC1101 8-pin module
Wiring:
CC1101 Pin 1 GND → ESP32 GND
CC1101 Pin 2 VCC → ESP32 3.3V
CC1101 Pin 3 GDO0 → GPIO26
CC1101 Pin 4 CSN → GPIO5
CC1101 Pin 5 SCK → GPIO18
CC1101 Pin 6 MOSI → GPIO23
CC1101 Pin 7 MISO → GPIO19
CC1101 Pin 8 GDO2 → GPIO27
Initial Results
The CC1101 initialized correctly and could immediately receive RF traffic.
The fan remote turned out to operate on 303.875 MHz rather than 433.92 MHz.
Using frequency: 303.875MHz allowed reliable reception of the MinkaAire remote. And,
ESPHome successfully decoded button presses using:
remote_receiver:
pin: GPIO27
dump:
- rc_switch
tolerance: 50%
filter: 100us
idle: 10ms
buffer_size: 30kb
Example decoded values:
Stop: 000000111101
Speed 1: 000000110111
Speed 2: 000000110101
Speed 3: 000000101111
Speed 4: 000000100111
Speed 5: 000000011101
Speed 6: 000000011111
Reverse: 000000111011
An end code of:
000000111111
was transmitted after commands.
However this produced weak and unreliable operations transmitting the codes using:
- remote_transmitter.transmit_rc_switch_raw:
and the fan would only respond at very close range and often required multiple attempts.
Solution
Switching to raw codes produced dramatically better results. Captured the original remote waveform with:
remote_receiver:
pin: GPIO27
dump:
- raw
tolerance: 50%
filter: 100us
idle: 10ms
buffer_size: 30kb
and replayed the captured waveform using for example this button for Stop:
on_press:
- remote_transmitter.transmit_raw:
code: [300, -376, 650, -376, 625, -400, 626, -375, 651, -375, 625, -376, 650, -701, 300, -726, 300, -700, 301, -725, 301, -375, 625, -726, 300]
repeat:
times: 16
wait_time: 20ms
Home assistant performance became comparable to the original remote and reliability improved substantially.
Recommendation
If you can successfully decode a device with rc_switch but transmission is unreliable, try capturing the actual waveform and replaying it with transmit_raw rather than relying on protocol-based retransmission.
For my MinkaAire fan this was the difference between "barely works" and "works like the factory remote."
