Esphome climate question
I’ve made use of the climate thermostat component and all is well. However I find the The lovelace card created allows an adjustment of 10 to 30C. I’m looking to adjust it down lower that just to prevent freezing. How / what can I edit to accomplish this?
i think you should adjust the min_temp in your configuration. The card must be just adopting these values. check out this
climate:
  - platform: generic_thermostat
    heater: switch.study_heater
    target_sensor: sensor.study_temperature
    min_temp: 15
    max_temp: 21
    ac_mode: false
    target_temp: 17
    cold_tolerance: 0.3
    hot_tolerance: 0
    min_cycle_duration:
      seconds: 5
    keep_alive:
      minutes: 3
    initial_hvac_mode: "off"
    away_temp: 16
    precision: 0.1
Thank you for the suggestion. I will try that this evening.
No I think it should be done in esphome
