I recently posted about esp device programming and thanks to the very helpful replies I managed to use esphome on a windows laptop to configure my device , which is now working very well to control an alarm key fob.
However there now presents a second problem.
How do I use ESPhome cmd line to configure other devices .
I read about a substitution file but that didn’t make sense.
So could anyone please tell me (in easy steps as my brain isn’t as powerful as the esp device) how to do this.
I do have a yaml file I want to use for the new device , which this time is a sunshade (awning) remote control I’d like to control via HA.
Thank you but how do I tell it which esp device to configure
I’ve only ever run the command with a single device on the network, but I now want to add a second esp board , so not sure how it will disguise which one to setup and I don’t want to trash the one I’ve already got working .
Get familiar with the following commands: compile - Validates and compiles the YAML run - Validates, compiles and uploads the YAML upload - Validates and uploads the most recently compiled binary
Note that run and upload can both take a parameter –device, which indicates which device to send the firmware to.
You can also specify the IP address in the YAML, and leave off the --device parameter. This is what I recommend. Reserve an address for each device in your router’s DHCP settings, and then include it in every ESPHome YAML configuration file. This self-documents everything and avoids any confusion or mistakes later.
