Esphome color temperature range
Hey there!
I have a remote for a desk light that I’ve modified with an esp but I’m running into an issue with the color temp. Basically the remote uses a rotary encoder for the brightness and color temperature which means I have “press” a button x number of times. I’ve gotten the brightness working but now the issue is that I can’t figure out the color temperature. The temperature range is 3000k-6500k but only has 15 steps in between the two. I currently have a number slider that works but I can’t integrate it into a light entity. I’m trying to figure out how I’d convert it so 15 would be 3000 and 0 6500k. Please ignore the code since I had to mash some scraps I found together. Please let me know if there is anything I could improve!
light:
  - platform: color_temperature
    color_temperature: templateout_temp
    brightness: templateout
    cold_white_color_temperature: 6500 K
    warm_white_color_temperature: 3000 K
globals:
  - id: brightness_prev
    type: int
    restore_value: no
    initial_value: '-1'
  - id: temp_prev
    type: int
    restore_value: no
    initial_value: '-1'
  - id: executed
    type: bool
output:
    type: float
    write_action:
      - number.set:
          value: !lambda |-
              return (int(id(desklight).remote_values.get_brightness()*41));
    type: float
    write_action:
      - number.set:
          value: !lambda |-
              return (int(id(desklight).remote_values.get_color_temperature()*15));
  - platform: gpio
    pin: D1
    inverted: true
  - platform: gpio
    pin: D2
    inverted: true
  - platform: gpio
    pin: D3
    inverted: true
  - platform: gpio
    pin: D5
    inverted: true
  - platform: gpio
    pin: D6
    inverted: true
button:
  on_press:
    - lambda: |-
        id(gpio_d1).turn_on();
        delay(5);
        id(gpio_d2).turn_on();
        delay(5);
        id(gpio_d1).turn_off();
        delay(5);
        id(gpio_d2).turn_off();
        delay(5);
  on_press:
    - lambda: |-
        delay(5);
        delay(5);
        delay(5);
        delay(5);
  on_press:
    - lambda: |-
        id(gpio_d5).turn_on();
        delay(5);
        id(gpio_d6).turn_on();
        delay(5);
        id(gpio_d5).turn_off();
        delay(5);
        id(gpio_d6).turn_off();
        delay(5);
  on_press:
    - lambda: |-
        delay(5);
        delay(5);
        delay(5);
        delay(5);
  on_press:
    - output.turn_on: gpio_d3
    - delay: 50ms
    - output.turn_off: gpio_d3
number:
    min_value: 0
    max_value: 41
    initial_value: 0
    step: 1
    optimistic: true
    on_value:
      then:
        - lambda: |-
            int steps = 0;
            //Just booted up? Get the LED strip to known value (0), otherwise get the difference
            if (id(brightness_prev) == -1)
                steps = -41;
            else
                steps = x - id(brightness_prev);
            //No difference? Don't do anything.
            if (steps==0)
                return;
            //Should we go up or down?
            auto button = steps>0 ? bright_up : bright_down;
            //How many steps?
            steps = abs(steps);
            //Press the button repeatedly
            for (int i=0;i<steps;i++)
                button->press();
                delay(3);
            ESP_LOGI("main", "Brigthness: %d -> %d", id(brightness_prev), id(brightness_slider).state);
            //Save current value for future change
            id(brightness_prev) = x;
    min_value: 0
    max_value: 15
    initial_value: 0
    step: 1
    optimistic: true
    on_value:
      then:
        - lambda: |-
            int steps = 0;
            if (id(temp_prev) == -1)
                steps = -15;
            else
                steps = x - id(temp_prev);
            if (steps==0)
                return;
            auto button = steps>0 ? warm : cold;
            //How many steps?
            steps = abs(steps);
                button->press();
                delay(3);
                ESP_LOGD("Custom", "Temp: %f", int(id(desklight).remote_values.get_color_temperature()*15));
            ESP_LOGI("main", "Temp: %d -> %d", id(temp_prev), id(temp_slider).state);
            id(temp_prev) = x;
Please can someone help me out I’m super confused :pray::pray::pray:
@jpsy A lot of the threads you have been on have been a massive help figuring this out! Do you have any advice you could give?
Hmmm… what exactly is your problem?
Are you trying to convert the range 0 to 15 into the range 3000 to 6500? That would be something like
(x/15 * 3500) + 3000
I’m trying to go from say 3000 to 1 or like 6500 to 15. I’ll try out your example and see if I can make something work. Thanks!
The slider in your code is not defined 1 to 15 but 0 to 15.
To convert the interval 3000 to 6500 into 1 to 15 you could do:
(x-3000) / 3500 * 14 +1
To convert the interval 3000 to 6500 into 0 to 15:
(x-3000) / 3500 * 15
