After setting the compile_process_limit: 1 in the yaml file my raspi 4 (2 GB) compile stable, but it takes a long time.
So I tried to move the compilation to my windows desktop. I installed the addon samba share on my HA system to be able to access the directory config\esphome which worked fine.
I was able to run the syntax validation at command line : esphome config “samba file share”
But running the compilation I get an error : UNC path not supported
I do not know what that means or how I can prevent it
PS C:\Users\PC RUDI 2019> esphome run \\192.168.178.55\config\esphome\d1mini.yaml
INFO ESPHome 2025.5.2
INFO Reading configuration \\192.168.178.55\config\esphome\d1mini.yaml...
INFO Generating C++ source...
INFO Core config, version or integrations changed, cleaning build files...
INFO Compiling app...
Processing d1mini (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
Library Manager: Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
INFO Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.3.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.3.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/noise-c @ 0.1.6
INFO Installing esphome/noise-c @ 0.1.6
Library Manager: Installing esphome/libsodium @ 1.10018.4
INFO Installing esphome/libsodium @ 1.10018.4
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
PLATFORM: Espressif 8266 (4.2.1) > Espressif Generic ESP8266 ESP-01 1M
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
PACKAGES:
- framework-arduinoespressif8266 @ 3.30102.0 (3.1.2)
- tool-esptool @ 1.413.0 (4.13)
- toolchain-xtensa @ 2.100300.220621 (10.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ off, Compatibility ~ soft
Found 41 compatible libraries
Scanning dependencies...
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.3.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.6
Building in release mode
Compiling .pioenvs\d1mini\src\esphome\components\adc\adc_sensor_common.cpp.o
"\\192.168.178.55\config\esphome\.esphome\build\d1mini"
CMD.EXE wurde mit dem oben angegebenen Pfad als aktuellem Verzeichnis gestartet.
UNC-Pfade werden nicht unterst\x81tzt.
Stattdessen wird das Windows-Verzeichnis als aktuelles Verzeichnis gesetzt.
xtensa-lx106-elf-g++: error: src\esphome\components\adc\adc_sensor_common.cpp: No such file or directory
xtensa-lx106-elf-g++: fatal error: no input files
compilation terminated.
*** [.pioenvs\d1mini\src\esphome\components\adc\adc_sensor_common.cpp.o] Error 1
================================================================================== [FAILED] Took 31.70 seconds ==================================================================================
