I’m trying to create a Sound Sensor from a D1 Mini and I’ve run into a bit of an issue compiling the project. I’m a complete muggle and know nothing about ESPHome or compiling. I’m just a simple nerd trying to follow this video tutorial https://www.youtube.com/watch?v=Akt4rSyNS_E
Any help would be greatly appreciated.
Here’s the code:
esphome:
compile_process_limit: 1
friendly_name: SoundSensor
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Soundsensor Fallback Hotspot"
password: "subscribe"
captive_portal:
# Example configuration entry
web_server:
port: 80
globals:
- id: esphome_sensitivity
type: float
initial_value: '36.5'
restore_value: yes
- id: esphome_volume
type: int
- platform: adc
pin: A0
device_class: signal_strength
name: "Db SoundEsp"
icon: "mdi:volume-vibrate"
unit_of_measurement: "db"
update_interval: 2s
raw: true
filters:
- lambda: |-
unsigned int sample;
unsigned long startMillis= millis();
float peakToPeak = 0;
unsigned int signalMax = 0;
unsigned int signalMin = 1024;
while (millis() - startMillis < 500) {
sample = analogRead(A0);
if (sample < 1024){
if (sample > signalMax){
signalMax = sample;
else if (sample < signalMin){
signalMin = sample;
peakToPeak = map((signalMax - signalMin),1,1024,1.5,1024);
id(esphome_volume) = peakToPeak;
float state = id(esphome_sensitivity)*log10(peakToPeak)+15;
return(state);
name: "Volume SoundEsp"
icon: "mdi:volume-high"
unit_of_measurement: "%"
update_interval: 2s
lambda: return(map((id(esphome_db).state),15,150,0,100));
name: "RAW SoundEsp"
icon: "mdi:volume-source"
update_interval: 2s
lambda: return(map(id(esphome_volume),1,1024,0,100));
number:
name: "Sensitivity SoundEsp"
icon: "mdi:knob"
update_interval: 5s
initial_value: "36.5"
step: 0.1
min_value: 20
max_value: 40
mode: slider
set_action:
then:
- lambda: id(esphome_sensitivity) = x;
And here’s the error:
INFO ESPHome 2023.8.2
INFO Reading configuration /config/esphome/esphome-web-33fbf3.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing soundsensor (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- ArduinoJson @ 6.18.5
Compiling /data/soundsensor/.pioenvs/soundsensor/src/esphome/components/api/api_pb2.cpp.o
xtensa-lx106-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [/data/soundsensor/.pioenvs/soundsensor/src/esphome/components/api/api_pb2.cpp.o] Error 1
========================= [FAILED] Took 171.05 seconds =========================
Thanks in advance for having a look.
