I’m trying to convert NodeMCU with a DHT22 and a BMP180 sensors to ESPHome, but the module will only boot once or twice before locking up. When it works, I can see the sensor readings on the web page OK. Disconnecting the sensors will allow it to boot. This was working fine in Tasmota. Here is the config:
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: 'MY_SSID'
password: 'MY_Password'
# Enable logging
logger:
web_server:
port: 80
# Enable Home Assistant API
api:
ota:
i2c:
sda: D1
scl: D2
scan: True
- platform: dht
pin: D8
model: dht22
temperature:
name: "Attic DHT Temperature"
humidity:
name: "Attic DHT Humidity"
update_interval: 20s
- platform: bmp085
temperature:
name: "Outside Temperature"
pressure:
name: "Outside Pressure"
