I have a ESP32 with ESPHOME flashed to it. I added two max6675 temp sensors to monitor the BBQ.
So When I login to the webinterface of the ESPhome device I can read all the sensor data.
I added the device in Homeassistant with the intergrations. From there everything works.
So the temp sensor data is passing trough to HA. But the device is not always on.
So if I let say not use the device for 3 days then when starting the ESP32 again the temp sensors are unavailable in HA.
But in the webinterface of ESPhome they are online. Now when I remove the ESP32 form the intergration and re add it it works again.
Or if I disable the unavailable sensors and reenable it works.
Here is the output of my config:
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: !secret ssid
password: !secret ssid_key
ap:
ssid: !secret ap_ssid
password: !secret ap_key
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret password
# services:
# - service: control_servo
# level: float
# then:
# - servo.write:
# id: pwm_servoBBQ
# level: !lambda 'return level / 100.0;'
ota:
web_server:
spi:
miso_pin: GPIO25
clk_pin: GPIO22
- platform: max6675
cs_pin: GPIO21
update_interval: 30s
- platform: max6675
name: "Probe 1 Temp"
cs_pin: GPIO19
- platform: homeassistant
entity_id: input_number.grill_probe_1_target
internal: true
entity_id: input_number.grill_alert_low
internal: true
entity_id: input_number.grill_alert_high
internal: true
- platform: wifi_signal
name: "esp_bbq WiFi Signal Sensor"
update_interval: 15s
- platform: adc
pin: 34
attenuation: 11db
filters:
name: "Accu spanning"
# on_value_range:
# below: 3.00
# then:
# - switch.turn_on:
# id: shutdown_esp_bbq
output:
# Servo Rotate : Using ledc output to control a standard 50Hz RC servo over the normal 1 to 2 mS pulse range
- platform: ledc
pin: GPIO27
frequency: 50 Hz
servo:
- id: pwm_servoBBQ
output: servoBBQ
switch:
- platform: gpio
pin: GPIO13
name: "Grill Alarm Buzzer"
icon: "mdi:grill"
turn_on_action:
- switch.turn_on: grill_alarm_buzzer
- delay: 500ms
- switch.turn_off: grill_alarm_buzzer
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
- platform: shutdown
name: "esp_bbq Shutdown"
i2c:
sda: 15
scl: 4
font:
- file: 'arial.ttf'
- file: 'arial.ttf'
- file: 'arial.ttf'
time:
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
reset_pin: GPIO12
address: 0x3C
pages:
- id: page1
lambda: |-
// Print time in HH:MM format
it.strftime(1, 0, id(font1), TextAlign::TOP_LEFT, "%H:%M", id(esptime).now());
it.printf(110, 0, id(font1), "%.1f", id(accu_spanning_bbq).state);
it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, "Actueel");
// Print inside temperature (from homeassistant sensor)
if (id(grill_temp).has_state()) {
it.printf(1, 23, id(font3), TextAlign::TOP_LEFT , "BBQ: %.1f°", id(grill_temp).state);
// Print outside temperature (from homeassistant sensor)
if (id(probe1_temp).has_state()) {
it.printf(1, 60, id(font3), TextAlign::BASELINE_LEFT , "Probe: %.1f°", id(probe1_temp).state);
- id: page2
lambda: |-
it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, "Target");
it.printf(1, 23, id(font3), TextAlign::TOP_LEFT , "BBQ: %.1f°", id(grill_alert_high).state);
it.printf(1, 60, id(font3), TextAlign::BASELINE_LEFT , "Probe: %.1f°", id(grill_probe_1_target).state);
interval:
- interval: 5s
then:
- display.page.show_next: my_display
- component.update: my_display
binary_sensor:
- platform: status
name: ESP BBQ Status
