ESPHOME control of Venetian blinds, tilt only, DC motor(not stepper motor) no MQTT
I need some help please. I am not a YAML programmer. I run my code through an online YAML code checker and it checks out valid/fine, but when I past it into the ESPHOME interface and try to install it onto the ESP8266 board - I get errors.
This will be to control Venetian blinds and just to tilt it, no up or down of the blinds itself.
Also, I am planning to use 12V DC motor, not stepper motor.
Can anyone please help and tell me what I am doing wrong/missing?
Thanks. Here is the code:
esphome:
friendly_name: Blind1
platform: ESP8266
board: esp01_1m
logger: null
api:
encryption:
key: "e...="
ota:
password: 7…d
wifi:
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.1.19x
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.1.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
dns1: 192.168.1.247
ssid: “A…”
password: “12…”
ap:
ssid: Blind1 Fallback Hotspot
password: "u5mD09Nqflfw"
output:
  • platform: esp8266_pwm
    pin: D1
    frequency: 1000Hz
cover:
  • platform: template
    optimistic: true
    tilt_command_topic: blinds_tilt/tilt
    tilt_status_topic: blinds_tilt/tilt_status
    tilt_min: -90
    tilt_max: 90
    tilt_closed_value: 0
    tilt_opened_value: 0
    tilt_invert_state: false
custom_component:
  • lambda:
    name: Blinds Tilt Controller
    update_interval: 50ms
    on_startup:
    - output.set_level: motor_pwm
    on_lambda:
    - int angle = id(blinds_tilt).current_tilt
    - int speed = map(angle, -90, 90, -1023, 1023)
    - if:
        condition:
          lambda: return speed < 0;
        then:
          - output.turn_on: motor_pwm
        else:
          - output.turn_off: motor_pwm
    - endif
    - output.set_level:
        level: return abs(x);
    on_tilt_command:
    - cover.template.set_tilt: blinds_tilt
      position: return x;
captive_portal: null
Also, I do not plan to use MQTT (will this even be possible) and I do not want any physical switches to press - if that is the case, I can just as well pull the string on the blind and then this will all be useless.
As I said - it appears to be clean when I run this through an online YAML checker, but when I paste it into ESPHOME, I get’s all kinds of errors - which I clearly do not understand.
Thanks for the help
