Anyone knows how to wire a D1 mini and a pcf8575 module such as this one
Also what would the code in esphome look like?
Connect the I2C bus (SDA to D2, SCL to D1) and power (Vcc to 3.3V, GND to GND).
It would look like the example in the documentation:
# Example configuration entry
pcf8574:
- id: 'pcf8574_hub'
address: 0x21
pcf8575: false
# Individual outputs
switch:
- platform: gpio
name: "PCF8574 Pin #0"
pin:
pcf8574: pcf8574_hub
# Use pin number 0
number: 0
# One of INPUT or OUTPUT
mode:
output: true
inverted: false
With the addition of the i2C configuration that is also required:
i2c:
sda: 4 # D2
scl: 5 # D1
scan: true
This is my code:
i2c:
- id: bus_a
sda: GPIO15
scl: GPIO4
scan: true
- id: bus_b
sda: GPIO4 # D2
scl: GPIO5 # D1
scan: true
pcf8574:
- id: 'pcf8575_hub'
i2c_id: bus_b
address: 0x21
pcf8575: true
switch:
- platform: gpio
pin:
pcf8574: pcf8575_hub
# Use pin number 0
number: 0
mode:
output: true
inverted: false
- platform: gpio
pin:
# Use pin number 1
number: 1
mode:
output: true
inverted: false
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
brightness: 1
update_interval: 0.5s
address: 0x3C
Now my screen is not working nor is this io extender (It just keeps my rgb led on green).
I have the the RGB connected as follows to the io expander: “-” → Gnd, “G” ->P00 and “R”–> P01
I used this but still nothing:
i2c:
- id: bus_b
sda: GPIO21
scl: GPIO22
scan: true
The pins on the io expander never turn off…
Keep getting:
Communication with PCF8574 failed!
OK got it to work finally…
What is the final config, problem and solution? I have the same board and i want to used it for extra GPIO pens for multicolor leds.
I used the following code to initialize the expansion board:
i2c:
- id: bus_a
sda: GPIO15
scl: GPIO4
- id: bus_b
sda: GPIO13
scl: GPIO14
scan: true
pcf8574:
- id: 'pcf8575_hub'
address: 0x20
i2c_id: bus_b
pcf8575: true
Important field is “address” without it my setup for some reason did not work.
I had 2 i2c hence the i2c_id field requirement.
And here is an example of a pin call:
switch:
- platform: gpio
restore_mode: RESTORE_DEFAULT_OFF
pin:
# Use pin number 0
number: 2
mode:
output: true
inverted: false
