Esphome dashboard errors
Hi All,
Having an issue and not sure whats wrong. Attempting to install and start esphome & dashboard on standalone linux box.
In following esphome instructions I have (venv) environment.
esphome version = Version: 2024.2.2
python3 version = 3.11.7
not that I am going to use it but esphome wizard test.yaml starts up fine (testing purpose)
I have run:
pip install tornado esptool
esphome dashboard config/
when I run esphome dashboard config/ home/me/directoryname or varients I get
unrecognized arguments error or
Erno 2 No such file or directory 'home/me/directoryname.
Im reasonably convinced esphome is working but the dashboard command or permission or location is where Im wrong.
Appreciate any advice.
Cheers
I think that should be config/ /home/me/directoryname
hi Nick
I get:
esphome: error: unrecognized arguments: /home/peter/
I have been playing around trying to figure it out. I think the syntax has changed. Try
esphome config /home/peter/whatever dashboard
But I find it hard to find anything definitive. Also it is a long time since I ran esphome outside docker/addons
yep I saw that somewhere when trying to fix this… the result is:
INFO ESPHome 2024.2.2
INFO Reading configuration /home/peter//…
ERROR Error while reading config: Invalid YAML syntax:
Error reading file /home/peter/esphome/projects/: [Errno 21] Is a directory: ‘/home/peter/’
Yeah its like it is looking for a valid esphome yaml file.
OK I think I have it
esphome dashboard /home/peter/whatever
You sir are a legend.
Thanks so much
