i have installed the ESPHome Device Builder over “Settings=>Add-ons=>ESPHome Device Builder”.
After start the ESPHome Addon with “Display on sidebar” and click on sidebar “ESPHome Builder” is nothing show. After few minutes display Error “add-on is not yet ready”.
On the Portainer, i have see the esphome-container is no network parameter like grafana, influxdb …
base system is restart.
The docker container from esphome (see in portainer) has no ip address an no port.
In tasklist from base system is running esphome (ps -A)
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: ESPHome Device Buildere[0m
e[34m Build your own smart home devices using ESPHome, no programming experience required.e[0m
e[34m Add-on version: 2025.2.0e[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Debian GNU/Linux 11 (bullseye) (amd64 / qemux86-64)e[0m
e[34m Home Assistant Core: 2025.2.5e[0m
e[34m Home Assistant Supervisor: 2025.02.1e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[19:32:53] INFO: e[32mConfiguring timezone (Europe/Berlin)...e[0m
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/30-esphome-fork.sh
cont-init: info: /etc/cont-init.d/30-esphome-fork.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
[19:32:55] INFO: e[32mStarting ESPHome dashboard...e[0m
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[19:32:55] INFO: e[32mWaiting for ESPHome dashboard to come up...e[0m
2025-02-25 19:32:56,412 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome...
[19:32:56] INFO: e[32mStarting NGINX...e[0m
[19:32:56] INFO: e[32mSuccessfully send discovery information to Home Assistant.e[0m
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2025-02-25 19:33:43,262 INFO 200 GET /devices (0.0.0.0) 1.58ms
