Hey Everyone,
I have a bunch of ESP8266 (D1 mini) devices on an off grid installation.
I’m getting a weird issues when the battery runs out, when the sun comes out again, and the battery starts providing power, none of my ESPHome devices come up automatically, maunally rebooting the ESPHome device works, (removing, reattaching power) It pops right up in the HA front end.
I think this is because the ESPHome devices boot almost immediately, but the router takes a minute to boot up, so the ESPHome devices are not ever “trying again” to reconnect to WiFi.
I have removed the ap config, specified a reboot_timout; 300s in the WiFi config, and done a clean install. But nothing seems to help.
Any pointers on how to force a D1mini to reboot after a period when it can’t connect to WiFI would be great, thanks!
Config:
esphome:
friendly_name: Bedroom
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "REMOVED"
ota:
- platform: esphome
password: "REMOVED"
wifi:
ssid: !secret wifi_ssid
reboot_timeout: 300s
captive_portal:
light:
- platform: monochromatic
output: output_component1
output:
- platform: esp8266_pwm
pin: GPIO15
switch:
- platform: gpio
pin: GPIO0
- platform: gpio
pin: GPIO2
binary_sensor:
- platform: gpio
pin:
number: GPIO16
mode:
input: true
inverted: true
on_multi_click:
- timing:
- ON for at most 400ms
then:
- homeassistant.event:
event: esphome.button_short_press
- timing:
- ON for at least 500ms
then:
event: esphome.button_hold
on_release:
then:
event: esphome.button_release
i2c:
sda: GPIO4
scl: GPIO5
scan: true
- platform: bme280_i2c
temperature:
name: "Bedroom Temperature"
pressure:
name: "Bedroom Pressure"
humidity:
name: "BedRoom Relative Humidity"
address: 0x76
update_interval: 15s
