After a recovery of my HA setup and update to the latest version of ESPHome + HA, I had the following problem:
An existing sensor (worked prior recovery) can’t be updated via OTA.
Details:
I had to restart my HA after a SD Card failure. Did a fresh install on a new SD Card and started HA from scratch. Auto discovery found the BME280 sensor and showed it’s values. I installed manually ESPHome and created a sensor config from my backup. Reboot of HA shows the device to be offline in the ESPHome dashboard. Not OTA update possible
Analysis:
The sensor had the DNS sensorgarten.local.
I changed the Wifi domaine the YAML to domain: “.fritz.box”, this allowed installs over wifi again.
However, the devices is still shown offline in the dashboard, but I can get logs and update.
Findings 1:
The ESP sensor can’t update via ESPHome, if the sensorgarten.local is used. Explicit config of th domaine fritz.box enables OTA.
Walter
Attachment: Environment
I am running:
Add-on version: 2021.10.2
You are running the latest version of this add-on.
System: Home Assistant OS 6.5 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2021.10.6
Home Assistant Supervisor: 2021.10.0
Wifi Network is based on a AVM Fritzbox (OS 7.28) with to Wifi repeaters
Browser is Firefox 93.0
I would agree to the statement “fix you mDNS”, but how? Enable Ping on the dashboard does not make the sensor online in the ESPHome dashbard.
Regarding the “next” SD card failure: Moved from “standard” SD to Max Endurance cards. This seems to be the card for solid lifetime. But I’d also like to mention that backup via snapshot does not automatically mean a restore is sucessful.
Hmmm, “endurance” sounds like the marketing worked.
the SanDisk MAX ENDURANCE microSD™ card is temperature-proof, waterproof, shockproof and X-ray-proof.2
Like all other SD cards too
But this card is anyway made for the opposite cause of your setup. It is optimized for continuous writing big junks of data (video recording for example). You are running a operating system and a database on it which writes small junks of data. Thank’s to write amplification the new card may even fail earlier than your old “standard” (maybe even a1 or a2 rated and therfor better suited) card.
Rather avoid any databases on SD cards at all and use a cheap ssd (even if it’s on usb) for that.
The SD Card thing is fair enough. I am fighting HA and ESPHome topics with every update. Before moving into a Pi4/SSD setup, I’d like to see HA work a bit stable. Not like the issue I am seeing now with the node that worked perfectly and is now offline after an update of HA/HAOS/ESPHome.
Any idea how to fix mDNS? Or how to get some leverage to raise sensible bug reports? I am lost (and currently writing the mDNS component documentation for the ESPHome web site).
I have installed HA in RPi3 as downloaded from homeassistant.io. No other stuff done by myself than adding the config folder to enable wifi. Homeassistant.local can be pinged from the PC. Sensorgarten.local can’t be pinged from the PC. I guess the node IP information is not distributed.
