hi,
i am making a doorbell project with esphome. When the D5 and GND pins are short-circuited, the system runs smoothly. I will input 1.2 V to this system through the A0 pin, and if the current is over 1 volt, I want to do the same by short-circuiting the d5 and gnd pins. If this is not possible, I can create a separate virtual switch and trigger it. Thanks in advance for the help.
binary_sensor:
platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
inverted: True
device_class: window
filters:- delayed_on: 10ms
platform: template
lambda: return (analogRead(A0) > 1.1);
on_press:
then:
- switch.toggle: diskapi
switch:
- platform: gpio
pin: D5
