ESPHome DutyTime
I have a dutytime sensor set up to display the runtime of a filter in hours, minutes and seconds. It displays properly but when it reaches 24 hours it resets to zero by itself with out anything calling the reset function.
Has anyone else encountered this behavior or know of a way to resolve it. I would eventually like to get the display working for days and hours.
Maybe your board is rebooting?
try with:
restore: true
I have restore: true. It’s not rebooting. I watched it roll over this morning.
Unexpected.
Feel free to post your yaml.
esphome:
  friendly_name: Aquarium
esp8266:
  board: esp01_1m
logger:
api:
  encryption:
    key: "redacted"
ota:
  - platform: esphome
    password: "redacted"
wifi:
  ssid: !secret wifi_ssid
time:
  - platform: sntp
output:
  - platform: gpio
    pin: GPIO03
switch:
  - platform: output
    icon: "mdi:air-filter"
    output: filter_pin
    restore_mode: RESTORE_DEFAULT_ON
    internal: false
    on_turn_on:
      then:
        - sensor.duty_time.start: filter_on_time
    on_turn_off:
      then:
        - sensor.duty_time.stop: filter_on_time
        - script.execute: publish_filter_runtime
  - platform: duty_time
    name: Filter On Time
    unit_of_measurement: s
    accuracy_decimals: 0
    restore: true
    internal: true
text_sensor:
    icon: "mdi:chart-bar"
    update_interval: 5s
    lambda: |-
      int seconds = round(id(filter_on_time).state);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      return {(
       (hours ? String(hours) + "h " : "") +
       (minutes ? String(minutes) + "m " : "") +
       (String(seconds) + "s")
      ).c_str()};
button:
    icon: mdi:air-filter
    on_press:
      then:
        - script.execute: reset_filter_runtime
script:
  - id: reset_filter_runtime
    then:
      - text_sensor.template.publish:
         state: !lambda |-
          return {(
          ).c_str()};
      - sensor.duty_time.reset : filter_on_time
  - id: publish_filter_runtime
    then:
         state: !lambda |-
          return {(
          ).c_str()};
When seconds rolls over to zero, int hours = seconds/3600, or 0/3600, =0
Try making a global to hold raw seconds and use that in the hours calculation…
I will look at that.
It shows properly up to 24:59:5x (since the updates are 5s it varies)
Then it returns to 0s and starts counting up again. I don’t have it listed in the yaml but I have a sensor that displays the raw value of the dutytime sensor and it also returned to 0.0 and started incrementing again.
For example duty time is one day and one second:
int seconds = round(id(filter_on_time).state); returns 86401s
seconds = seconds % (24 * 3600); 86401 % 86400 returns 1
int hours = seconds / 3600; returns 0
seconds = seconds % 3600; returns 1
int minutes = seconds / 60; returns 0
seconds = seconds % 60; returns 1
Set your duty time sensor
internal: false
and see the real duty time
And if you like to convert the time delete this line:
Thank you @Karosm !
Was able to get it to work with the following:
state: !lambda |-
          int days = seconds / 86400;
          seconds = seconds % 86400;
          return {(
           (days ? String(days) + "d " : "") +
          ).c_str()};
