I’m trying to debug what my airconditioner is sending via UART, so far I havent had any luck seeing any data at all and I assume its due to the UART settings being incorrect, I am making my way through variations but recompiling takes time each change and I want to be able to dynamically cycle through options.
I’ve managed to cobble together some partial code through copilot but the intracacies of the cpp api are stumping me
substitutions:
friendly_name: Living Room Aircon
esphome:
friendly_name: ${friendly_name}
esp32:
board: esp32dev
framework:
type: esp-idf
# debug:
# update_interval: 10s
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
uart:
baud_rate: 9600
stop_bits: 2
parity: NONE
tx_pin:
number: RX
rx_pin:
number: TX
debug:
direction: BOTH
dummy_receiver: true
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid
select:
- id: change_baud_rate
platform: template
options:
- "2400"
- "9600"
- "38400"
- "57600"
- "115200"
- "256000"
- "512000"
- "921600"
initial_option: "9600"
optimistic: true
restore_value: true
entity_category: config
icon: mdi:swap-horizontal
set_action:
- lambda: |-
id(my_uart).flush();
uint32_t new_baud_rate = stoi(x);
ESP_LOGD("change_baud_rate", "Changing baud rate from %i to %i", id(my_uart).get_baud_rate(), new_baud_rate);
if (id(my_uart).get_baud_rate() != new_baud_rate) {
id(my_uart).set_baud_rate(new_baud_rate);
id(my_uart).load_settings();
- id: change_stop_bits
platform: template
options:
- "1"
- "2"
initial_option: "2"
optimistic: true
restore_value: true
set_action:
- lambda: |-
uint8_t new_stop_bits = stoi(x);
ESP_LOGD("change_stop_bits", "Changing stop bits from %i to %i", id(my_uart).get_stop_bits(), new_stop_bits);
if (id(my_uart).get_stop_bits() != new_stop_bits) {
id(my_uart).set_stop_bits(new_stop_bits);
- id: change_parity
platform: template
options:
- "NONE"
- "ODD"
- "EVEN"
initial_option: "NONE"
optimistic: true
restore_value: true
set_action:
- lambda: |-
UARTParityOptions new_parity;
if (x == "NONE") {
new_parity = UARTParityOptions.UART_CONFIG_PARITY_NONE;
} else if (x == "ODD") {
new_parity = UARTParityOptions.UART_CONFIG_PARITY_ODD;
} else if (x == "EVEN") {
new_parity = UARTParityOptions.UART_CONFIG_PARITY_EVEN;
} else {
new_parity = UART_PARITY_DISABLE;
ESP_LOGD("change_parity", "Changing parity from %i to %i", id(my_uart).get_parity(), new_parity);
if (id(my_uart).get_parity() != new_parity) {
id(my_uart).set_parity(new_parity);
- id: change_tx_pin
platform: template
options:
- "GPIO1"
- "GPIO3"
initial_option: "GPIO1"
optimistic: true
restore_value: true
icon: mdi:pin
set_action:
- lambda: |-
// Expecting the option format "GPIO<number>"
std::string pin_str(x.c_str());
if (pin_str.find("GPIO") == 0) {
int new_tx_pin = stoi(pin_str.substr(4));
ESP_LOGD("change_tx_pin", "Changing TX pin to GPIO%i", new_tx_pin);
auto *new_pin = new ESP32InternalGPIOPin();
new_pin->set_pin(static_cast<gpio_num_t>(new_tx_pin));
id(my_uart).set_tx_pin(new_pin);
- id: change_rx_pin
platform: template
options:
- "GPIO1"
- "GPIO3"
initial_option: "GPIO3"
optimistic: true
restore_value: true
icon: mdi:pin
set_action:
- lambda: |-
int new_rx_pin = stoi(pin_str.substr(4));
ESP_LOGD("change_rx_pin", "Changing RX pin to GPIO%i", new_rx_pin);
new_pin->set_pin(static_cast<gpio_num_t>(new_rx_pin));
id(my_uart).set_rx_pin(new_pin);
- id: change_data_bits
platform: template
options:
- "5"
- "6"
- "7"
- "8"
initial_option: "8"
optimistic: true
restore_value: true
icon: mdi:format-letter-case
set_action:
- lambda: |-
uint8_t new_data_bits = stoi(x);
ESP_LOGD("change_data_bits", "Changing data bits from %i to %i", id(my_uart).get_data_bits(), new_data_bits);
if (id(my_uart).get_data_bits() != new_data_bits) {
id(my_uart).set_data_bits(new_data_bits);
I get a few compile errors and am going in circles somewhat
/config/living-room-aircon.yaml: In lambda function:
/config/living-room-aircon.yaml:113:39: error: expected primary-expression before '.' token
113 | new_parity = UARTParityOptions.UART_CONFIG_PARITY_NONE;
/config/living-room-aircon.yaml:115:39: error: expected primary-expression before '.' token
115 | new_parity = UARTParityOptions.UART_CONFIG_PARITY_ODD;
/config/living-room-aircon.yaml:117:39: error: expected primary-expression before '.' token
117 | new_parity = UARTParityOptions.UART_CONFIG_PARITY_EVEN;
/config/living-room-aircon.yaml:119:22: error: cannot convert 'uart_parity_t' to 'esphome::uart::UARTParityOptions' in assignment
119 | new_parity = UART_PARITY_DISABLE;
| uart_parity_t
/config/living-room-aircon.yaml:146:29: error: expected type-specifier before 'ESP32InternalGPIOPin'
146 | auto *new_pin = new ESP32InternalGPIOPin();
/config/living-room-aircon.yaml:170:29: error: expected type-specifier before 'ESP32InternalGPIOPin'
170 | auto *new_pin = new ESP32InternalGPIOPin();
Can anyone point me in the right direction to get this working or alternative firmware that might be better suited to this?
