My configuration for esp camera doesn’t work after update to ESPHome 2025.11.1. What’s wrong? The configuration was ok before the update. Now the section with esp32_camera is highlighted with error This option requires component psram.
esphome:
friendly_name: ESP Camera 6
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
captive_portal:
esp32_camera_web_server:
- port: 8080
mode: stream
- port: 8081
mode: snapshot
esp32_camera:
name: "ESP Camera 6"
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 1024x768
#resolution: 800X600
jpeg_quality: 20
max_framerate: 10 fps
brightness: 2
aec2: True
ae_level: 2
agc_gain_ceiling: 4X
vertical_flip: True
horizontal_mirror: False
frame_buffer_count: 1
