ESPHome external component: setup() and loop() never called on Component + UARTDevice
Summary
I have an external ESPHome component for controlling a Tesla Wall Connector Gen 2 via RS485. The component is correctly registered via App.register_component() in the generated main.cpp, but setup() and loop() are never called. Even with ESP_LOGE as the very first line of setup(), nothing appears in the logs.
Environment
- ESPHome version: 2026.2.0
- Board: Olimex ESP32-POE-ISO (esp32-poe-iso)
- Framework: Arduino
- Python: 3.14.5
Component structure
The component inherits from Component, uart::UARTDevice and TeslaControllerIO:
class TWCController : public Component, public uart::UARTDevice, public TeslaControllerIO {
public:
void setup() override;
void loop() override;
void dump_config() override;
The __init__.py registers it like this:
async def to_code(config):
var = cg.new_Pvariable(config[CONF_ID])
await cg.register_component(var, config)
await uart.register_uart_device(var, config)
Generated main.cpp (relevant part)
twc = new twc_controller::TWCController();
twc->set_component_source(LOG_STR("twc-controller"));
App.register_component(twc);
twc->set_uart_parent(twc_uart);
App.setup(); // called at line 613
So App.register_component(twc) IS called, and App.setup() IS called. But setup() inside the component is never reached.
What I see in logs
dump_config() IS called (showing TWC ID, min/max current, flow control pin), but setup() is never called. Even this does not appear:
void TWCController::setup() {
ESP_LOGE(TAG, "SETUP CALLED!!!"); // never appears in logs
What I tried
- Changed inheritance order (Component first, then UARTDevice)
- Changed
get_setup_priority()fromAFTER_CONNECTIONtoDATA - Moved initialization to
loop()withinitializedflag —loop()is also never called - Cleared build cache completely
- Downgraded ESPHome to 2026.2.0
Question
Why would setup() and loop() not be called on a component that is registered via App.register_component()? Is there something about combining Component with uart::UARTDevice registration that prevents this?
The component is based on https://github.com/jnicolson/esphome-twc-controller
Any help appreciated.
