ESPHome firmware compilation causes homeassitant system restart
I am running HA ver 2025.10.3 (HassOS) and ESPHome ver 2025.10.2 an a raspi 4 with SSD disk. Several ESPs connect via WLAN gather sensor information (T&H, air quality, reed switch, infra red, hall, …) and espcam. Statistic data are stored in a Influxdb and visualized with Grafana. I update the main software components continouesly. Because I didn’t change any yaml configuration within the last months, I didnt not update the ESPs.
Trying to add a new sensor I was forced to do an update and it did not work anymore.
If I do the update via the ESPHome Builder it starts compiling
INFO ESPHome 2025.10.2
INFO Reading configuration /config/esphome/esphome-web-a99bb4.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-a99bb4 (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP @ 2.0.0
|-- ESP8266WiFi @ 1.0
|-- ESPAsyncWebServer @ 3.7.10
|-- DNSServer @ 1.1.1
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.10
Compiling .pioenvs/esphome-web-a99bb4/src/esphome/components/adc/adc_sensor_common.cpp.o
Compiling .pioenvs/esphome-web-a99bb4/src/esphome/components/adc/adc_sensor_esp8266.cpp.o
Compiling .pioenvs/esphome-web-a99bb4/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esphome-web-a99bb4/src/esphome/components/api/api_frame_helper.cpp.o
and stops with the file shown above and a few seconds later the HA server disconnects. After reconnecting you can see, that the HA server has restartet.
I turned on the debug mode of ESPHome but there is no error message in the log and also the HA log doesn’t show an error.
I have no idea what’s going on - I’m looking for some help.
I wonder if it could be a raspi pi brown-out?
What does your pi cpu and memory look like before and during the compile?
What power supply are you using for your pi?
How much ram :question:
Looks how? How many cores for compiling? Running out of memory? :thinking:
Try setting compile_process_limit: to 1 in the esphome: block and see if it still happens.
  • compile_process_limit (Optional, int): The maximum number of simultaneous compile processes to run. Defaults to the number of cores of the CPU which is also the maximum you can set.
This is the reason I switched to a NUC from the Pi 4, I did start by moving my ESPHome compiles to Mac using command line, but the speed and robustness of using the NUC won out in the end.
Seconding this.
Your symptoms are exactly what I was experiencing when I originally started using ESPHome years ago. Took a really long time before I figured it out, since none of the documentation (at least at the time) gave any guidance or suggestions on needing beefier hardware.
Many thanks to all of your replies. I’m using a raspi 4 with 2 GB.
Setting the compile_process_limit solved my problem. ESPHome compiling with limit 1 I had a CPU usage of 50-60% and mem usage of 55-70%. The usual usage is CPU < 10% and mem < 50%. I have to think about a faster system.
I really appreciate your support.
I was struggling with similar issue (but on RPi3). It is out of memory problem that leads to kill a compiling process. In a matter of fact at some point you will hit that problem again. Better option is to configure ESPHome Builder on Windows/Linux computer, build there and upload firmware with one of three available option
  • web serwer
  • ESP home cli
  • “web monitor” (I think)
    All is well documented and pretty easy to use.
Before buying new hardware, try the command-line option on another device like a laptop or desktop. When you think about it, it doesn’t really make sense to do your development work (e.g.; compiling) on your production HA machine.
