ESPhome globals above
Hi
I try to do some automation
I get error (expected float.)
globals:
   - id: Min_Cooler_Temperature
     type: float
     initial_value: '6'
   - id: Max_Heater_Temperature
     type: float
     initial_value: '80'
   - id: Temperature_Difference
     type: float
     initial_value: '2'
                    - if:
                        condition:
                          - sensor.in_range:
                              above: id(Min_Cooler_Temperature) + id(Temperature_Difference)
                        then:
                          - delay: 2s
Rather than using sensor.in_range, you might have to use lambda. As in:
- if:
  condition:
    lambda: 'return id(Cooler_Temperature).state > id(Min_Cooler_Temperature) + id(Temperature_Difference)
I haven’t tested it, but you don’t get any immediate errors with the code.
thanks @michaelblight its work
