Esphome has an integration path but..... inkbird308
while a module swap is needed, there IS Esphome documentation to install Esphome on a Inkbird 308 temperature controller., My Q here, is will this also work for the Inkbird 306 (humidity controller) Obviously some code jockeying would be in order. But as these are tuya devices needing a data ident to read back, the 308 data points have been identified (see esphome docs) I’m wondering if anyone knows the 306 data point code idents (numbers) or does anyone know if they are the same as the 308 just different numbers and symbols?
